R56 oil turbo feed lines
Old May 4, 2025 | 02:09 PM
minifanboy's Avatar
minifanboy
replaced the turbo oil lines and the oil filter housing gaskets as part of the major service.
About to button the car up today - should I dry fire the car? Pull the fuel pump fuse and crank it a few times to build oil pressure? To a) check the pressurized part of the system for leaks and b) don't fire the engine totally dry when I do eventually start it up
I have a ECS scanner so I can clear the stored codes I'm sure will pop up as I have a bunch of sensors disconnected
Old May 6, 2025 | 04:43 AM
Seaswood's Avatar
Seaswood
Dry fire?
when I was done with just started that tells if you have any leaks.
had to replace coolant expansion tank & cover, new cover leaked put old cover back on.
& clear codes!
DVSoul
R55 :: Clubman Talk (2008+)
Sep 23, 2024 03:50 PM
Yngbld14
Apr 13, 2024 04:54 AM
ioannes79
Aug 24, 2017 09:04 AM
Hoover23
Jun 26, 2017 01:29 PM
theimage
Jan 4, 2014 12:38 PM
