R56 Hood scoop chrome overlay?
Old Apr 23, 2025 | 10:04 AM
Lex2008's Avatar
Lex2008
Anyone have any advice on chrome hood scoop overlaps?
My body colored scoop cracked. Certainly not going to pay to paint a primed unit.
Old Apr 25, 2025 | 07:05 AM
habbyguy's Avatar
habbyguy
Why not just replace the entire scoop with a chrome one? I put a chrome hood scoop on my project Mini (though mine is a base, non-turbo model). Looks great.
A couple cautions though... the screws that hold the black plastic "grille" in the scoop were far too big for the holes, and shouldn't be used. I've also heard that the heat from a turbo engine can be hard on the plastic chrome layer. I have no idea, but am not worried since my Mini is normally aspirated.
At any rate, here's a video I did on my hood swap (including the installation of the scoop)...
Old Apr 25, 2025 | 09:17 AM
Lex2008's Avatar
Lex2008
Because it costs $250....
Old Apr 25, 2025 | 09:40 AM
habbyguy's Avatar
habbyguy
The scoop I got (though it was aftermarket) was (IIRC) under $70. It's only been on a month or so, but is holding up and looking just fine.
Old Apr 25, 2025 | 09:47 AM
Lex2008's Avatar
Lex2008
The one I bought from @ECS Tuning It is an overlay with tape. Does that require me to remove the old one or just slap it over the cracked unit? It has 2 sided tape.
Old Apr 25, 2025 | 11:36 AM
Hello,
Thats the peal and stick. Goes overtop. Make sure the old ones is clean and isopropyl alcohol might be needed if you have too much wax or cleaner on the paint of the original scoop.
Should be ok unless the hood scoop from the factory is really warped or wavy. Then i have seen people add more tap to make it seal.
Test fit it first to make sure nothing on the old scoop is jacked up.
Its not a true flush fit to the hood level. It sets up a mm or two over the hood line like anything that added on top.
Old Apr 25, 2025 | 11:37 AM
Lex2008's Avatar
Lex2008
Hello,
Do you have an aftermarket that is not peel and stick?
Old Apr 25, 2025 | 11:50 AM
Genuine MINI mounted one is NLA, and all we have is overlays.
Old Apr 25, 2025 | 11:57 AM
Lex2008's Avatar
Lex2008
thanks @ECS Tuning
ti22fjc
Jun 4, 2015 06:37 PM
BubbaJCW
Jul 17, 2014 09:47 PM
mrmagoo
R55 :: Clubman Talk (2008+)
Jun 23, 2008 05:11 PM
laurendesigns
May 3, 2008 11:38 AM
