R56 Oil catchcan spot ???
Old Feb 19, 2024 | 04:47 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
So my aftermarket intake makes it almost impossible to run a catchcan in-between the intake and valve cover..
caaaaaaan I run a catchcan on the other side of the pcv system ? Like in the hoses that comes off the left rear side corner of the valvecover after it goes through the pcv ????? It woooooould still filter that crap befor it got sucked into the intake manifold. Because I seen the pcv system uptop does get decent amount of condensation in it ( I have a aluminum valvecover, it's serviceable)
would that be better to run a catchcan on that side of the pcv vs not running one at all ??? Or is that a usrless spot ( though i can't imagine it's useless )..
Old Feb 22, 2024 | 08:31 AM
Coz3z3's Avatar
Coz3z3
Here's where mine sits. I notice you have the hood latch alarm thing though it seems. Don't mind the dirt lol
Old Feb 25, 2024 | 05:23 AM
MiniManAdam
Community Builder
yes I know.i had mine there too but are you plumbed off the manifold to valve cover ?
Old Feb 25, 2024 | 10:54 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
On the N14, I think the most beneficial catch can install will be on the line from the cam cover to the intake manifold. The line from the cam cover to the turbo inlet will have less impact.
Old Feb 25, 2024 | 12:17 PM
Jason Cornelius's Avatar
Jason Cornelius
if he’s really that worried I would do both, if I had an n14 and didn’t block off the passenger side. Driver side you will only really notice anything during the winter months. Yes I ran my passenger side blocked off for pretty much the whole time I had the car, still had to walnut blast the intake valves, that fixed my misfire issue.
Old Mar 6, 2024 | 06:12 AM
MiniManAdam
Community Builder
Thanks for the info guys...
I will run a 2x can setup soon and hopefully down the road do the block off or 3x port catchcan setup..
Old Mar 8, 2024 | 07:45 PM
MiniManAdam
Community Builder
could I block off the intake manifold port and run both valve covers lines into a 3x port catch cam and then have the 3rd port go to my intake then ??? Or am I not understanding the vacuum routing correctly ??
Old Mar 9, 2024 | 04:07 AM
Jason Cornelius
honestly I don’t know it it would work or not. I’m not trying to pull the search button on you here, but I can’t remember what videos I watched where they explained the system. When I decided to block passenger side ports, my goal was to try to cut down what was hitting the valves, which I still had to walnut blast them. I would do both if I had to do it again. There is a kit, don’t remember company, that is made for both, I think they were overseas though.
Old Mar 9, 2024 | 07:39 AM
MiniManAdam
Community Builder
yea your rite..Best just do 2x to be safe..
So I will be running a dual can system them.. i just ordered 2x cans i hope are going to work.
the one I have is stupid, the in-line is on the right side not the left like most cans and they come out at and angle away from each other and make routing the lines impossible. I also might have to switch my intaje to an n18 style or vice versa ( not sure which style intake I have actually) but I will also buy more rubber hosing since I used the last of it running my own pcv line out the valvecover to the manifold .I broke that pos plastic hose and tried for over an hour to install an oem one but just couldn't get tge routing correct so I said screw it.
I have all the room I need too to run a dual can because I'm running a homemade intake now.
DefoMini08
Feb 15, 2022 10:55 PM
MiniManAdam
24
Dec 20, 2020 07:31 PM
sani
Oct 2, 2017 08:15 AM
user 7398330
Sep 24, 2013 08:05 PM
ThumperMCS
Dec 13, 2010 08:23 AM
