R56 R56 oil leak
Old Jul 21, 2023 | 07:36 AM
  #126
Lex2008's Avatar
Lex2008
Correct, unless the joint loses all its grease and then the joint self destructs from friction/heat.
Old Jul 21, 2023 | 10:43 AM
  #127
Seaswood's Avatar
Seaswood
S model sports package, I do not see any wiring going to strut assuming these are not electronic adjustable struts?
Old Jul 21, 2023 | 12:09 PM
  #128
Lex2008's Avatar
Lex2008
keep dreaming bro. This is the worst suspension ever...its certainly not variable damping.
Old Jul 21, 2023 | 01:57 PM
  #129
Seaswood's Avatar
Seaswood
It looks no better than the front shocks I changed on the Defender 1984 last fall I think they were Original difficult to get off difficult to get spring compressed get that nut on!
looking at set all with springs /damper /retaining cap.
Old Jul 23, 2023 | 09:56 AM
  #130
Seaswood's Avatar
Seaswood
Looks like the arm aft of the CV arms has a rubber bellows on it also that is slightly damaged this is above the support arm which blocks the view from below. Also attaches to the wheel hub/ bearing. Stabilizer link?
how tight is the wheel hub nut, flange nut 134 lbs!
seems you need a good extension to remove this.
Then some.
techman1
Jul 18, 2023 12:34 PM
Mcoaster
Dec 13, 2022 05:00 PM
RSRG
Jan 18, 2016 07:50 AM
preme123
Dec 13, 2014 08:15 AM
allgrainer
Jun 29, 2014 01:41 PM
