R56 n18 PCV cover?
Old Jan 8, 2023 | 05:13 PM
white46's Avatar
white46
n18 PCV cover?
My car, with n18 motor, is experiencing cold start idling issue.
When engine is cold, rpm bounces up and down for couple of minutes and smooth out afterwards.
While search for the fix, I noticed the PCV cover is not seated fully.
Wondering... should the cover closed fully? or should there be a gap?
Old Jan 9, 2023 | 12:58 PM
Yea, should snap down. Are you getting a hissing noise? My guess is the clip in side on the valve cover might be damaged.
https://www.ecstuning.com/b-hamburg-...27646552v~ham/
Old Jan 10, 2023 | 07:29 AM
white46's Avatar
white46
Thank you.
Yesterday, while driving, CEL P0171 was triggered.
Open the hood, found that the PCV cap was gone. I guess because it wasn't fully seated, it popped out and flew away..
Old Jan 10, 2023 | 07:56 AM
bagwell's Avatar
bagwell
be careful you don't break any tabs when replacing
Old Jan 10, 2023 | 08:53 AM
^^ +1 yes check those clips otherwise you will need a new whole cover. Which comes with a New rear corner PCV.
https://www.ecstuning.com/Search/Sit...h/11127646552/
Old Jan 10, 2023 | 07:39 PM
white46's Avatar
white46
Yeah.. ended up replacing whole valve cover.
Luckily was able to find a decent used OEM valve cover for $40 locally. Job done.
Old Jan 11, 2023 | 04:14 AM
DogfaceSGM's Avatar
DogfaceSGM
Glad you found the problem, sorry it was the more expensive of the two.
I just replaced my PCV. I am hoping it lessens my oil consumption. No leaks and about a quart per 1000 miles. It only has 63000 on it. I know I have read that Mini's use oil and I have had turbo vehicles in the past but that seems a bit excessive to me.
Old Jan 11, 2023 | 03:37 PM
DogfaceSGM's Avatar
DogfaceSGM
Checked my oil level today, 500+ miles after doing the oil change and the PCV. I am happy to report it was right at the top of the dipstick.
Old Jan 11, 2023 | 04:09 PM
white46's Avatar
white46
Awesome.
I was too loosing engine oil without obvious leaks. I was thinking it's either PCV or valve stem seal.
Since my PCV is fixed, I'll monitor oil level. Thanks!
Old Jan 28, 2023 | 02:44 PM
DogfaceSGM's Avatar
DogfaceSGM
At 1000 miles now and oil level has barely changed. Very happy I changed the PCV!
Old Feb 13, 2023 | 06:15 AM
DogfaceSGM's Avatar
DogfaceSGM
Has it helped your oil consumption?
I am at 2500 miles now since changing it and still very little change in the oil level. So glad I changed it!
Old Feb 15, 2023 | 09:12 AM
white46's Avatar
white46
Mine is still burning but not as bad as before.
I think the next up is the valve stem seal, which I should do together with timing chain.
Or...
just sell it..? :D
Old Mar 9, 2023 | 04:23 PM
DogfaceSGM's Avatar
DogfaceSGM
Fueled up today and checked the oil. 1st time adding since changing the PCV, 1/2 qt at 2700 miles. that beats the heck out of 1 qt per 1000-1500 miles.
jncunha
Apr 20, 2022 08:01 AM
Tom.R56
Apr 3, 2019 10:56 AM
countrymanwot
Dec 8, 2018 10:21 AM
mdun6
Mar 26, 2015 09:33 AM
<05MINI>
Aug 20, 2013 02:23 PM
