R56 Crank no start after head work
Old Sep 8, 2022 | 05:35 PM
Szel's Avatar
Szel
Hi. I'm completely baffled. I'll preface this with that I am a very experienced mechanic, just not highly versed in mini.
A while back I burned an exhaust valve. Replaced all the valves and now, no start. I am absolutely positive the cams are in time, I've rechecked and rechecked. What am I missing? Is there a fuel priming issue I don't know of? What could I have possibly left unhooked that could cause an absolute no start? I'm beyond frustrated... Halp.
Old Sep 8, 2022 | 10:56 PM
oldbrokenwind's Avatar
oldbrokenwind
If all valves were replaced, do a compression check. Sometimes the valves will be too long and not close when on the cam flats.
Then there's ground connections that MUST be made --- the big one on the engine mount and the small one in front of the coils (for the R56).
Here's a BMW timing check procedure, maybe it will help --- https://bmwrepairguide.com/mini-r56-...er-all-models/
Old Sep 11, 2022 | 05:59 PM
Szel's Avatar
Szel
Think I've covered all that. Compression seems good, all grounds in place, great spark, rpm changes on scanner. The only code present is one for the thermostat control that I know I had before.
Old Sep 11, 2022 | 06:33 PM
Coz3z3's Avatar
Coz3z3
Did you change the timing chain as well? If not, then how much slack was in the chain? When I did mine, my timing was lined up spot on where I didn't think I had a problem. No start either. Once I got the new chain and compared them, I had so much slack in the original, no wonder it wouldn't start.
Old Sep 11, 2022 | 07:51 PM
oldbrokenwind
Gotta agree with Coz3z3, chain slack can cause your problem. That link I sent earlier isn't the best procedure, there are others. Let me know via NAM messaging if you want more procedures. Here's a quick way to measure chain slack ---
Shields Racing
Apr 28, 2022 03:23 PM
ricardiini
Jun 28, 2021 02:08 PM
dieseldogpi
Dec 31, 2018 06:37 AM
DrewGzy
Mar 5, 2018 08:16 PM
thabeana
Oct 14, 2014 06:01 AM
