R56 Some noise, some play. Front Drivers Axle?
Old Mar 30, 2021 | 03:36 PM
Lipofskyphoto's Avatar
Lipofskyphoto
I'm noticing a new noise like the drone of airplane engines when your onboard the plane. Not super loud, but noticeable. No excessive vibration.
The noise persists in neutral. It's not the engine. No vibration from gearshift.
I inspected the axles and the drivers side axle has some play where it enters the trans when I grasp the section indicated by the arrow.
Should this be dead tight? If not, I'm suspecting this is the culprit.
Old Mar 30, 2021 | 06:20 PM
cooper48's Avatar
cooper48
Wheel hub bearing does that.
Old Mar 31, 2021 | 08:37 AM
Lipofskyphoto
No play in bearings.
Next time one of you is under the car, if you could grab the driver's side axle as shown (the part that enters the trans) and give it a wiggle and report back if there is any play, that would be helpful.
Thanks!
Old Mar 31, 2021 | 09:08 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Thanks!
A little bit of in-and-out play at the transmission on the drive shaft is normal. That is the clearance for the little circlip.
Wheel bearings do not need to be loose to make noise. They can be tight and still be noisy. I would expect wheel bearings before axel or transmission issues.
Old Mar 31, 2021 | 11:03 AM
Jonathan Jones's Avatar
Jonathan Jones
The best way to check wheel bearing is to jack up the whole front end put the vehicle in neutral take the wheel off and rotate the hub assembly. If you hear any noise at all then replace it. A good bearing will be silent. Some resistance is normal of course but if there is a large amount of resistance it is also an indicator thst it is bad.
Old Mar 31, 2021 | 11:05 AM
Lipofskyphoto
Thanks, but this is side to side play, not in and out.
I suspect that three way universal.
I'd like to hear from someone as to whether they have side to side play there.
It's more common for noisy wheel bearings to have some play than not.
Old Mar 31, 2021 | 12:13 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
When the CV joint starts going out, you'll hear a clickity clack noise, mostly when turning. When a bearing starts going, you'll hear more of a whirring noise that will increase with speed.
Of course, all that being said, its near impossible to diagnose sounds over an internet forum.
Old Mar 31, 2021 | 01:11 PM
Lipofskyphoto
Yes, I do understand that.
Again, my hope is that someone with check to see if there is ANY side play in the drivers axle where it enters the trans when gripped as shown in the photo above.
Old Mar 31, 2021 | 10:15 PM
renchjeep's Avatar
renchjeep
Does the noise change with side-loading while driving? Like when driving on a straight section of road, when the noise is happening, with room to do so of course, turn the car slowly left to right, back and forth a few times. Does the noise change in loudness or pitch? If it does, that would indicate a hub bearing going out. And I don't think that inboard CV joint should be dead-tight in the transmission. It will have a bit of lateral movement. I will check mine ASAP, and report back. I need to put my 2011 MCS up on all 4 to do an oil change this weekend at some point anyway.
Old Mar 31, 2021 | 11:59 PM
Jonathan Jones
So if you have this light roaring noise while driving and in any gear or neutral while moving. have ruled out wheel bearings and you have 1 axle that moves in/out of the trans alot more than the other axle. My next step would be to remove that axle and inspect the bearing in the transmission.
Old Apr 1, 2021 | 08:54 AM
Lipofskyphoto
Renchjeep
Thanks. No noticeable change when moving left and right.
The noise is not all that loud and some might think it "normal", but it seems to me to be new.
On Facebook, one person said there should be no play, another that some play is normal.
Again, I'm not talking about in and out or the trans. I'm talking about a side to side movements when the axle is gripped where I indicated on the above photo.
Looking forward to your report! Use jack stands. I don't want to lose you!
Old Apr 2, 2021 | 04:28 PM
Lipofskyphoto
OK, I have the answer. I was at a Mini dealership to pick up oil filters and the service manager stated emphatically that there should be NO lateral movement of the axle as it enters the trans.
Old Apr 3, 2021 | 08:40 AM
renchjeep's Avatar
renchjeep
Well, mine does have some lateral movement, and I can't recall ever seeing a CV shaft of this type that didn't move at least a tiny bit laterally where it enters the transmission. I tried uploading a video here, but could not. It's not much movement, maybe 1/8 inch? If you send me a PM with your cell number, I can send you the video.
Old Mar 22, 2025 | 07:00 AM
Pnielsen2110's Avatar
Pnielsen2110
Same issue, was a solution ever found?
lipofskyphotos I have the same issue. It’s a long shot 4 years after this post but I am a newbie and unable to message you directly. Were you ever able to find the source of the noise? Mine is exactly how you describe and “feels” like the vibration is central instead of outward towards wheel bearings. Thank you in advance
Old Mar 22, 2025 | 11:48 AM
habbyguy's Avatar
habbyguy
I agree with the others on this thread who suggest that it's a lot more likely to be a wheel bearing than a munged inner CV axle joint. The inners are under much less stress, unless of course you've slammed your car, in which case they're under a lot more stress, but I'd still suspect the wheel bearings.
Spend $8 and get yourself a Harbor Freight mechanic's stethoscope, and take a listen to the wheel bearings (yes, while gently rotating the wheel back and forth).
Old Mar 24, 2025 | 08:59 AM
Lipofskyphoto
It turned out that the noise was coming from the wheel bearing, even though there was no play.
Later, I had the same problem with the other wheel bearing I replaced them both.
Old Mar 24, 2025 | 09:45 AM
Pnielsen2110
Thank you!
gknorr
Oct 1, 2015 09:20 AM
SPDinNY
Jul 3, 2015 03:26 PM
12funsize
R60/R61 Stock Problems/Issues
Feb 26, 2015 12:07 PM
plasticknives
Feb 9, 2010 08:40 PM
jollyroger927
Aug 1, 2009 10:14 AM
