R56 R56 Mini One engine swap
Old Jan 30, 2021 | 04:26 AM
HenryClement's Avatar
HenryClement
Hi everybody, I’ve just signed up to this site in the desperate hope of some help and advice
My Mini One engine is in need of replacing as it has just failed. It comes stock with a 1.4 petrol n12b14 engine however it seems like a shame to replace the engine in it with the same measley 95hp engine. Does anyone have any knowledge about if the 1.6 engine is transferrable onto the one? Or if any other engines can be put in it?
Im not the most gifted with cars but I’d love any help or advice any of you can retrieve for me.
Many thanks
Henry
Old Feb 1, 2021 | 06:23 AM
mrbean's Avatar
mrbean
It's certainly possible but it's not an easy "drop in."
If you have a blown motor an want more power it would be easier and likely more cost effective just to buy a used cooper or cooper S.
Old Feb 1, 2021 | 10:35 AM
thebombardier's Avatar
thebombardier
Many thanks
Henry
I don't know if the 1.4 and 1.6 naturally aspirated engines share ECUs or wiring harnesses or transmissions. So that's something to investigate. If you're lucky you'll only have to swap the entire engine. Worst case scenario everything in the front of the car will have to be swapped and reprogrammed to the car. Either way it probably won't be worth it considering you can buy an R56 base Cooper or Cooper S for under $5k these days.
buggyeye401
Mar 16, 2011 09:02 PM
fm.illuminatus
Feb 26, 2009 05:55 AM
mini_r53
Mar 19, 2007 08:13 PM
turbo740
Jul 29, 2005 01:39 AM
