Drivetrain Engine swaps!
Old Feb 4, 2009 | 12:37 AM
fm.illuminatus's Avatar
fm.illuminatus
Engine swaps!
Has anyone done, or is considering doing an engine swap on an R56. Over on Bimmerforums there is a whole section dedicated to the subject in BMW's anyone done a swap on a Mini? Why, why not?
Old Feb 4, 2009 | 01:29 AM
Puma|Mini's Avatar
Puma|Mini
I know there's a V6 race Mini out there. I think it's RWD too, but I don't know where the pix are right now... I'll page through my EuroTuner mags tomorrow and see if I can't find it.
In other news, I want an e92 335i engine in my Mini...
Old Feb 4, 2009 | 06:07 AM
a96bimmerm3's Avatar
a96bimmerm3
Believe its an e46 m3 motor thats in that mini. The reason why you haven't seen many swaps in R56s is that the amount of work and fabrication required to do really any swap is pretty steep, and the cars are basically new. Also, the only worthwhile swap would be fwd to awd or rwd, and its really difficult, not to mention you'd be butchering a basically new mini. (not cost effective)
Old Feb 4, 2009 | 01:09 PM
ghosthound's Avatar
ghosthound
Engine swaps are more common in larger cars because their engine bays can contain a larger engine... the MINI engine bay is so small theres not much bigger of an engine/transmission you could stick in their.
The only thing i could think of is haveing the engine inside the cabin area behind the driver which would require TONS of custom fab work.
Old Feb 4, 2009 | 02:31 PM
Mutley MCS's Avatar
Mutley MCS
I remember seeing video once of a Tiburon with a V6 in the front and another in the rear, each engine driving through its transaxle giving AWD.
Turbo 1.6 in the front, another in the rear, AWD 3.2L twin turbo with over 400hp, that would go! Horribly expensive to do though.
Old Feb 4, 2009 | 04:17 PM
eR1c's Avatar
eR1c
it's not uncommon common to stick small block v8's in small spaces i.e. :
-Porshce 914
-Pontiac Fiero
-Older Porsche 911's
-British MG's
..these are the smaller cars that I can think of off hand that people put v8's into ...I don't think space is an issue w/ the MINI. I think the other issues already mentioned are more of the reason (cars are too new, not cost effective).
check out this link:
http://www.britishv8.org/British-Hot...to-Gallery.htm
Old Feb 4, 2009 | 10:57 PM
Mutley MCS's Avatar
Mutley MCS
What about the guy in the UK that put a chev 454ci into an old school mini, insane. He moved the firewall and the drivers seat was where the rear seat used to be. Has to be the largest engine in the smallest car I have heard of.
Old Feb 6, 2009 | 12:10 AM
fm.illuminatus
See, that's what I was thinking
Old Feb 6, 2009 | 12:16 AM
fm.illuminatus
Speaking of transmissions, how easy would it be to swap out the lower ratio MCS tranny for the higher ratio MC transmission?
Old Feb 15, 2009 | 11:11 PM
Puma|Mini's Avatar
Puma|Mini
Found it! Way later... but I did find it.
Old Feb 18, 2009 | 02:38 PM
fm.illuminatus
Oh that's beautiful.
Old Feb 18, 2009 | 04:43 PM
inimini2007's Avatar
inimini2007
Honda's VTEC engine has been done to a Classic Mini and UK GEN 1.
Old Feb 19, 2009 | 06:28 AM
Noegel's Avatar
Noegel
Mazdaspeed3 engine would be sweet, but I couldn't imagine the amount of work it would be to fit any larger engine in the MINI... it is already tight as is with the tiny 1.6L.
It sure does pull for 1.6L... my friends at work, after I gave them a ride asked if it had a V6... I politely told them it has a 1.6L inline 4. Always surprises them!
Old Feb 26, 2009 | 05:55 AM
a96bimmerm3
I think it would be much cheaper and better if you put a 28rs on it or something
danielbrookes_9
Oct 3, 2015 12:51 PM
Knuckle14
Aug 26, 2015 08:10 PM
makg
Aug 21, 2015 02:49 AM
vanhick
Aug 19, 2015 09:03 AM
