R56 N18 Engine slight RPM movement
Old Dec 27, 2020 | 08:53 PM
yyj3869's Avatar
yyj3869
I recently purchased 2013 R60 N18 Engine Mini Countryman S with 55K miles.
I've replaced air filter (it was really dirty) and cleaned Mass air flow sensor & spark plugs and ignition coils and had oil change. I kind of hoped oil change and spark plugs and ignition coils made change for idle problem however, It didn't seem like working out. I recorded a few videos as a reference. RPM moves up and down slightly (not erratically) and I do feel little vibration when rpm goes little down and I don't know why rpm bounce up and down when I shift in every gear when it stopped. Please advise!
there is no error code and CEL
Old Dec 28, 2020 | 05:21 AM
Staxtis's Avatar
Staxtis
I cant be sure if this is normal or not but seems like it is actually!
Most of the cars do that RPM bounce(minimal) when you are in idel and start moving the wheel etc etc.
If you turn on your car wait 1-2 minute in order to end the cold start,,,and you dont do ANY move on steering or anywhere....It shouldnt bounce!
Old Dec 28, 2020 | 07:58 AM
yyj3869's Avatar
yyj3869
RPM is not steady even if I don't do any move on steering wheel. It happens when cold/warm and also happens when stopping at traffic lights etc. It also seems to happen when I press the brake harder while stopped at a light. No other issues at all. no loss of power.
Old Dec 28, 2020 | 05:31 PM
yyj3869's Avatar
yyj3869
car vibrates when rpm drops...
Old Dec 29, 2020 | 11:01 AM
Mark_SF's Avatar
Mark_SF
I think the RPM "bounce" as you put it, is the ECU doing what it should to increase revs prior to a downshift, to make for a smoother gearshift.
There's nothing wrong with that car in either video.
Old Dec 29, 2020 | 11:04 AM
yyj3869's Avatar
yyj3869
That's not what I'm talking about. I know downshift makes rpm bounce up My problem is when the car is stopped at light and idling and rpm goes down and back to normal with vibration.
Old Dec 29, 2020 | 12:32 PM
Minifenrir's Avatar
Minifenrir
I don't think there is really an issue with your car but another possibility is a vacuum leak. The PCV valve on the valve cover is one common vacuum leak on these cars.
Old Dec 29, 2020 | 01:58 PM
Mark_SF's Avatar
Mark_SF
I was observing mine this morning when I drove it. After coming to a stop the revs drop to a lower idle rate. This is quite common in modern cars, that the idle rate has a couple of levels and is lowered when at lights.
Yours might have a little bit of instability in the idle rate. I'm not sure how the N18 controls idle. Is there an idle or auxiliary air valve, does anyone know? If there is, I would clean it.
BTW, mine does not go to the lower idle rate when A/C is on. You might also try sport mode, I bet this keeps the idle higher.
Old Dec 30, 2020 | 03:30 AM
thebestbear's Avatar
thebestbear
Keep an open mind, or let me blow it for you.
I'll think your battery may be weak. Probably a dead cell.
My reasoning.
That steering is electric and puts a draw on the system. The alternator can't do it all at idle. You need 12.2 volts or higher constant, from the battery.
Idle is too low, when not using wheel. They all vibrate at 700 rpm. Low idle is also a symptom of low voltage from the battery.
Mini service will never tell you this. They just don't understand electrical theory.
How do I know? Happened to me. Took 3 dealer visits and then battery died and I knew, once they replaced it, that that was it, all along.
Want to test this theory?
Make sure both battery terminals are clean.
Get a battery load test at a battery supplier like VIP, or whoever you have that has a load tester and knows how to use it and make sure off voltage is 12.4-13.9 volts. Any lower, replace it.
Try sitting with engine off and emergency flashers on for two hours. Can't do it? replace battery.
If battery seems good after all these tests, it may be that alternator / regulator. Hopefully it's just a battery.
You may think I sound crazy, but I'm telling you, batteries cause tons of issues you would not expect.
Have fun. ;-)
https://youtu.be/t8h0CWHUrzs
https://youtu.be/VLRTBXYtrTA
Old Dec 31, 2020 | 02:45 PM
yyj3869's Avatar
yyj3869
My reasoning.
Have fun. ;-)
I recorded one in the morning. Please let me know if you notice something. Thanks for your help! Happy New Year!
Old Jan 1, 2021 | 06:29 PM
Lou@Prototype-R's Avatar
Lou@Prototype-R
Vendor
Looks like normal behavior. On cold start rpm is raised in order to bring the catalytic converter up to operating temperature as quickly as possible. The ecu also compensates for additional torque loads placed on the engine by the AC and alternator. When decelerating to a stop the ecu is going from a very lean condition and returning to a lambda of 1.0. This does not happen instantaneously and the ecu uses timing for idle correction so some bounce until fueling stabilizes is normal.
Custom tuning solutions for BMW & Mini.
Old May 24, 2023 | 09:06 AM
Jas0123's Avatar
Jas0123
https://youtu.be/AapqdjdBoBE
hey, have you gotten it solved?
mini-is-for-me
Sep 30, 2019 05:33 PM
chrunck
Jun 23, 2018 07:48 AM
Mikey Jones
Jun 11, 2018 09:50 AM
MINIIZM
Nov 10, 2017 10:43 AM
Flyinace2000
Apr 21, 2016 12:41 PM
