R56 P0301 code
Old Oct 17, 2020 | 06:51 AM
William Mejia's Avatar
William Mejia
P0301 code
hello, everyone. new here and i have a ‘09 mini copper JCW w/ the N14 engine. my issue started while i was on the highway and it suddenly lost power. CEL came on and started flashing. my initial thought was spark plugs or coil packs so i went and did all four plugs and all four coil packs. problem persisted. scanned it and received a P0300 (random/multiple cylinder misfire), P0301 (cylinder 1 misfire), and P0302 (cylinder 2 misfire). thought it could be carbon build up so i removed intake manifold and fuel rail w/ injectors. walnut blasted all four intake ports and had injectors serviced. also replaced intake manifold gaskets and throttle body gasket and replaced the fuel filter. put everything back together and problem persisted. next on the list was the HPFP since it was reading pressure in the 700’s at cold start. replaced and problem persists only now i’m only getting a P0301 (cylinder 1 misfire). this where i’m currently at.
any ideas on what else it could be? any input is greatly appreciated! thanks!
Old Oct 19, 2020 | 06:23 PM
cpmetz's Avatar
cpmetz
Timing chain.
Old Oct 20, 2020 | 03:32 AM
Jason Cornelius's Avatar
Jason Cornelius
Run a compression test across all 4. Hopefully they all come back in the same range.
FrankBlack
R55 :: Clubman Talk (2008+)
Nov 5, 2019 10:22 AM
trwtestengineer1
Jul 30, 2019 12:08 PM
benjohnson
Aug 12, 2016 04:56 PM
ksweet00
Dec 1, 2015 08:38 AM
murderedmini
Sep 12, 2013 11:24 AM
