R56 Just bought my daughter a mini. R56 I think?
Old Oct 14, 2020 | 02:51 PM
C_Heath's Avatar
C_Heath
Well, My 16 year old wanted a Mini so being such a great kid in these trying times, I sprung for a 2010 S turbo 2dr HB. I think its the R56? it has 120k and is in really good shape. The previous owner had it for 8 years. I do have limited auto experience but I did get a Mini Code reader. It has went into limp mode once or twice and came out on its on. I'm getting the codes 2885, 2880
and PF22 and I've already read them. I will be doing the HPFP along with oil, air filter and spark plugs this weekend. The plugs, I just want to change since I have no idea when they were last changed. As an addition to these, Ill also install at boost pressure sensor since its relatively easy to do via the location as well as the engine coolant temp sensoralong with the thermostat adapter lead. Maybe this will clear the PF22 even though the cooling fan is not running the entire time and the engine is not overheating.
My biggest worry is the 2885 being a bad turbo but I am going to scout the hoses and connections to make sure that they are all secure and no air is escaping. I will also install a new diverter valve this weekend with everything else. Is there anyone who can suggest how to check the play in the wastegate? I've read that it should be a maximum opening of 8mm? I don't have a vacuum gun. If anyone has any tips or tricks or something special that I need to do or look for please let me know. I'm a GM guy so ill be learning as I go this weekend. lol
Thanks! Glad to get good info on this site so far
Old Oct 14, 2020 | 05:55 PM
AZdsrt's Avatar
AZdsrt
Yep, R56. Be prepared, these cars are not cheap to maintain or repair.
Old Oct 14, 2020 | 06:32 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Welcome, yes a 2010 S is an R56
Save your money and don't bother with replacing the boost sensor, I've never seen one fail so that likely isn't your issue. You'll need to do some diag, but if you grab the waste gate rod while it's cold and it's loose the turbo is likely your issue as they are known to fail.
https://www.waymotorworks.com/stock-...8-r59-r60.html
Old Oct 15, 2020 | 10:29 AM
C_Heath's Avatar
C_Heath
I was able to get my hand down in there this morning and feel the waste gate rod. It didnt have any side to side play but it had a tad bit of up and down play. Still hoping its not the Turbo. Thanks again.
Old Oct 15, 2020 | 02:43 PM
ssashton's Avatar
ssashton
Blimey, 16yr old with a 170hp hatchback! How's the insurance? Are you in the US?
Here in the UK I couldn't sell my Cooper S to a new driver because nobody would insure her.
Old Oct 16, 2020 | 06:14 AM
C_Heath's Avatar
C_Heath
its not bad. I just have the only required coverage on it. nothing extra
Old Oct 16, 2020 | 12:21 PM
MacMini34's Avatar
MacMini34
My kid got his licence just before he turned 17 and we went up $1000 a year on the 2 cars, a 2011 MCS and a 2009 Honda Pilot full insurance on both. The MCS took the brunt of increase. We're in Massachusetts, USA. He's getting to like driving Barry the Cooper now and has got pretty good at using a clutch.
cheers
MacMini34
Old Oct 17, 2020 | 11:15 AM
C_Heath's Avatar
C_Heath
Well I got it all installed. Took it a while to get a decent idle. Scared me for a minute. Ran like crap for about 5-10 min and cleared up. All the codes that was thrown were gone and all stayed away but the 2885 boost pressure plauseabilty Code. It came back as well as the half engine light. It’s strange because it still has killer power even with the half engine light on. Isn’t it supposed to be in limp mode when that light it on? No change in power either way. Back to the drawing board but the other codes are gone. Thanks for the help guys so far
Old Oct 17, 2020 | 11:27 AM
Jason Cornelius's Avatar
Jason Cornelius
Just wondering if you have replaced the divertor valve yet?
Old Oct 17, 2020 | 11:28 AM
C_Heath's Avatar
C_Heath
yes
high pressure pump
temp sensor
diverter valve
oil, filter
plugs
all 4 coils
air filter
Old Oct 17, 2020 | 04:21 PM
CachacoMCS's Avatar
CachacoMCS
You are an awesome dad. If the turbo fails, go all out and get Stage 3 RPM tune from MarioKart on this forum. Need turbo, intercooler , Downpipe, etc and you'll love it so much that you will keep the MCS for yourself and give the kid some Toyota Yaris!
my kid certainly wants to keep mine.
Old Oct 17, 2020 | 04:23 PM
C_Heath's Avatar
C_Heath
Lol thanks! that’s one beautiful mini. I just want to get this thing running good so I can get back to my boat lol.
Old Oct 17, 2020 | 04:27 PM
CachacoMCS's Avatar
CachacoMCS
Give it some time and you'll be asking your daughter to borrow her car to get to wherever you have your boat!
yyj3869
Mar 9, 2020 05:42 PM
Ginger Hulk
R60/61 Cooper S Drivetrain
Feb 8, 2020 07:34 AM
tylenol
Jun 3, 2018 09:31 AM
tkenupp
Jan 19, 2018 07:51 PM
Jpainter187
R55 :: Clubman Talk (2008+)
29
Feb 11, 2017 09:04 AM
