R56 H&R springs, is this height correct?
Old Apr 13, 2019 | 04:24 AM
R56NJ's Avatar
R56NJ
I installed some H&R Springs over the weekend the front came down normally looks lowered but the rear seems a little bit off....
It looks almost too high in the rear I don't know if it's supposed to be like that or if I did something wrong...
I even tried swapping out shocks when I had it on the OEM shocks it was the same right now it's on Stagg shocks..
Can anyone confirm if this is how it's supposed to look..
Old Apr 13, 2019 | 06:15 AM
tman's Avatar
tman
I had same results after installing Eibach lowering springs.
Ended up cutting 3/4 coil off the springs and it sit almost level now.
Spring rate increases when cutting springs but ride quality is still good.
Old Apr 13, 2019 | 01:33 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Yeah, rear looks high. Maybe you got the convertible or Clubman springs? Those are longer in the back due to the extra weight.
Old Apr 13, 2019 | 01:36 PM
MarioKart's Avatar
MarioKart
Vendor
Just cut 3/4 of a coil off the top rear coils. It will give look you want
Mario
mQubed Motorsport Manic & RPM Power Tuning
Old Apr 14, 2019 | 09:44 AM
R56NJ's Avatar
R56NJ
I'm pretty sure I ordered the correct model number of Springs I ordered from Alta.. idk this is a picture of the box...
I guess I'm just going to have to cut off 3/4 of top of spring off.....
I have to say the ride quality is nice but the looks it is just not what I was expecting, I'm actually pretty disappointed in these lowering springs.... and I'm not a fan of cutting springs..
Old Apr 14, 2019 | 04:42 PM
Alpha Motoring's Avatar
Alpha Motoring
It looks like that, it'll settle a bit more
Old Apr 22, 2019 | 03:09 AM
Digitys's Avatar
Digitys
Yes give it some miles before you cut the spring. I did NM springs years ago and it took a few days of driving for everything to really settle in.
replacement
Mar 15, 2017 02:14 PM
abadgti
Suspension
Jan 15, 2012 11:19 AM
eg3
Suspension
Oct 4, 2010 02:32 PM
ponie5
Suspension
16
Sep 9, 2009 10:30 PM
ekim
Suspension
11
Nov 3, 2006 01:27 PM
