R56 R56 Piston Ring Question - Oil Ring Spacer Sizing
Old Nov 3, 2018 | 09:28 AM
Mininewb101's Avatar
Mininewb101
Hello All, I did some searching last night and failed to find the information I needed. I have google and my parts place stumped.
I am rebuilding an 2007 (build date 06/07) Turbo R56 6 Speed Mini. I have ordered Piston rings from two different vendors and they both came in, different brands but same sizes. The oil spacer does not physically fit into the piston ring groove. I was wondering if mini changed pistons mid build or? From my understanding the oil ring was an issue on these cars... the reason I am rebuilding this one.
The top compression/oil rings sit in the piston as should and I checked them in the cylinder, all good. The oil ring just appears to be slighting to large. I will log into my phone and post some photos.
If anyone has any information I would appreciate it! Happy Saturday.
Old Nov 3, 2018 | 09:34 AM
Mininewb101
https://ibb.co/iMbg8L
https://ibb.co/eESA2f
https://ibb.co/j8R3Nf
https://ibb.co/bZxXF0
https://ibb.co/dbSXF0
https://ibb.co/mFzev0
https://ibb.co/iZiiNf
It is not letting me upload attachments sorry gents.
Old Nov 3, 2018 | 10:45 AM
oldbrokenwind's Avatar
oldbrokenwind
Take a look at https://www.newtis.info/tisv2/a/en/ --- enter the last 7 characters of your VIN and scroll thru to find the tech info on pistons, rings etc.
Repair Manuals and Technical Data
Engine
11 25 Pistons with Rings and Pins
This'll get you to both repair instructions and specs for your specific engine. Maybe look at RealOEM for part OEM part numbers.
Old Nov 6, 2018 | 08:52 AM
Yupetc's Avatar
Yupetc
Go to realoem.com and enter your car's production date, that should get you where it needs to be.
AvianMan
Mar 30, 2020 07:12 AM
Bcoday
May 19, 2018 08:07 AM
dajiggalo
Sep 2, 2017 07:08 AM
genik
Apr 5, 2014 08:04 AM
JCampos
Tires, Wheels, & Brakes
Sep 19, 2009 05:26 PM
