R56 Tachometer Swap and now problems
I got my new to me 2013 Cooper S and hated the new Tach vs my 2007 that showed the temp and time. While at the junk yard there was a 2007 that had the gauge pods built into the side.. Well little ole me bought them for $50.00 came home and installed it. Mileage showed 50,xxx which is the correct mileage and all was well.. Fast forward 3 months and Im going to the gym and look down and its 122,000!!!
I swapped the old gauge back into the car but now it briefly shows 52,xxx (which is correct) but then goes back to 122,xxx. I pulled the terminals off the battery for a couple days when I was away but that didnt help. My question is will it figure it out and go back to the 52,000?
Thanks!
Thanks!
oh my...it happened to me while I was rebuilding my flooded 2013 mini. Basically, the concept is the computers will sync data (not all, but some are "sync-able") and mileage could be one of those data entries. It will store the highest number and will always add the numbers.
When I had that issue, I called my "service tech" out in IL and was able to restore my mileage. I had to send him the ECU, CAS, keyfob, cluster, and tachometer. They all needed to be synced the same time.
I might need his info!
precisionecu@gmail.com technician name is Andy. Tell him Salah from philly referred you. tell him the story and what he needs to get it fixed
he is also here on ebay https://www.ebay.com/usr/6167
.he is also here on ebay https://www.ebay.com/usr/6167
Interior/Exterior Swap my chrome OEM tachometer trim ring for yours in silver?
WEEGIT
Feb 11, 2006 06:22 PM
