R56 what are these two parts?
Old Jul 21, 2017 | 09:21 AM
genik's Avatar
genik
Can somebody tell me what these two parts are?
Old Jul 21, 2017 | 09:51 AM
Sleepy289's Avatar
Sleepy289
A - oil pipe from engine block to turbocharger
B - water pump
Old Jul 21, 2017 | 01:51 PM
genik's Avatar
genik
Originally Posted by Sleepy289
B - water pump
Is it just one water pump?
Old Jul 21, 2017 | 01:57 PM
Sleepy289's Avatar
Sleepy289
The R56 has a mechanically driven water pump like the one in the picture and then an auxiliary electric powered water pump just before the turbo (between turbo and coolant tank).
Old Jul 25, 2017 | 02:32 PM
B - water pump
Yep,
B. Should be noted its the main water pump. For the turbos they have an additional aux water pump. All noted here:
https://www.northamericanmotoring.co...8-no-heat.html
Old Jul 25, 2017 | 05:44 PM
genik's Avatar
genik
I see, so is it safe to say that when one replaces the Thermostat for leaking, this water pump is also replaced?
Old Jul 25, 2017 | 07:25 PM
yesti's Avatar
yesti
I would suggest the water pump and the plastic water tube between the pump and thermostat be replaced if they are original, since you are in there already.
Old Jul 26, 2017 | 03:32 AM
genik's Avatar
genik
I was told that the thermostat usually needs replacing because its made out of plastic and the heat corrodes the form and it no longer is able to seal tightly. Is this true?
Old Jul 26, 2017 | 07:38 AM
I did them all at once so I would not have to do it again.
The thermostats develop a crack on the seam near the base or on the seam itself. For heat and time the material just starts to flex from heat cycles. The newer thermostat I replaced seemed to hold up better.
Old Jul 26, 2017 | 05:51 PM
yesti's Avatar
yesti
On my car the temp sensor went even though the housing was not leaking (yet?). You might be able to replace just the sensor but when you realize the thermo is a plastic POS that gets exposed to boiling+ hot water changing the whole thing seems reasonable since you have to take it out anyway. Since you have to take it out anyway, you need to unclip it from the plastic water tube that connects to the water pump. If that thing leaks you need to remove the thermostat to replace it. So might as well replace the tube with the thermostat. Last thing is the water pump, which is also plastic. Then you are all good for another 30k miles
Old Jul 27, 2017 | 02:49 AM
genik's Avatar
genik
Plastic my @ss, im sick n tired of using cheap parts to save money. They dont make cars like they used to damn it, its all about the money. Buying and replacing parts is what automobile companies want!
Old Jul 27, 2017 | 08:27 PM
yesti's Avatar
yesti
Since they want the car to run hot for emissions but not explode when under heavy load the plastic parts, and the various fluids, take a beating. I got a manic stage 2 tune partially because it runs the car at 90C versus 105+C. If you have a turbo and/or automatic transmission both are cooled by engine coolant at some point so lowering the operating temps are sure to help those components in the long run.
Old Jul 27, 2017 | 08:38 PM
genik's Avatar
genik
Interesting but what parts have you installed to have the manic 2nd stage tune? I suppose an intercooler at least?
Old Jul 28, 2017 | 06:21 PM
yesti's Avatar
yesti
stage 2 requires high flow air filter replacement, intercooler, downpipe replacement and nkg 1422 plugs (1-2 steps colder depending on what you have stock)
Charlie Victor
Feb 14, 2019 07:32 AM
Bearybee
May 5, 2017 05:53 PM
MyMiniAdventure
Feb 20, 2017 06:59 AM
MyMiniAdventure
Jan 23, 2017 03:15 PM
