R56 Rebuilt engine locks up when turning by hand?
Old Jul 28, 2017 | 11:32 AM
timcluff's Avatar
timcluff
Finishing up my engine rebuild and I have bored the cylinders to 77.5 mm and now I am working on the timing. I have rotated the crank at least 3 full revolutions, but now it doesn't want to move at all... Any ideas?
Old Jul 28, 2017 | 04:17 PM
TVPostSound's Avatar
TVPostSound
Valve interference?
Have you assembled the timing chain yet?
Old Jul 28, 2017 | 04:40 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Will it turn then stop, and allow you to turn it backwards? Or does it not turn at all in either direction?
Old Jul 28, 2017 | 04:49 PM
oldbrokenwind's Avatar
oldbrokenwind
This is an "interference" engine --- if timing is in-correct,(oops! pretty stupid mistake) valves MAY run into the pistons. Also, hand rotation, when timing chain is installed, must be done ONLY in the CW direction, when viewed from the passenger side --- Vanos doesn't like CCW. If you turned it over before adjusting timing, you better start over with the timing adjustment. Hopefully, you're using the Bentley manual or applicable TIS for guidance. Maybe mention the year / model, engine, etc?
Old Jul 29, 2017 | 12:35 PM
timcluff's Avatar
timcluff
2009 mini cooper s, I have the specific timing tool and I going off a youtube video as well as tops from a tech at the mini dealer
Old Aug 1, 2017 | 11:06 AM
BigBoost's Avatar
BigBoost
Might be kind of a weird question !!! Buttttt!!!!! Did you use the correct sizes rods?
