R56 Monster Mini, WTF???? Why is the thing such a high roller??
Old Feb 19, 2017 | 08:44 PM
Grip Grip's Avatar
Grip Grip
I snagged an R56 today that's stanced like a monster truck. Obviously the tires are oversized 215/60-15, but that doesn't explain the huge gap in the fender wells. Any ideas on what's going on? The springs looked stock.
At this point, the damn car looks like a tortoise!
Old Feb 19, 2017 | 08:52 PM
thebombardier's Avatar
thebombardier
Maybe it's the angle of the picture, but pic #5 actually makes it look like there are spacers between the strut plates and the body of the car, which shouldn't be. How deep in that center hole is the top nut of the strut?
Old Feb 19, 2017 | 08:59 PM
Grip Grip's Avatar
Grip Grip
The strut plate in this pic is around 1.5" - 2" from the body. It is clearly different compared to my R53's.
Old Feb 20, 2017 | 04:45 AM
thebombardier
Well there's your 2" of lift. The strut top plate should be against the body of the car. Interesting way to lift but I'm sure this is ****ing the suspension geometry in some way.
Old Feb 20, 2017 | 05:43 AM
Grip Grip's Avatar
Grip Grip
Looks like someone installed a coopercrap kit on it: http://www.crapindustries.com/coopercrap-home/r5556-2-lift-kit/index.html
I'd never heard of a lifted Mini Cooper until now. Looks to be a real PITA to remove.
Old Feb 20, 2017 | 11:45 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
I say install some mudder tires and a big light bar across the top. Maybe a Hella horn to boot.
Old Feb 20, 2017 | 12:03 PM
Bnourai's Avatar
Bnourai
Welcome to my world with R56 as it is they look like a 4x4 in the back without those spacers..i have the coilovers awaiting me finding a right wheels,my 17x8.25 et22 with 215/45/17's made it look even taller.
Attached Thumbnails Monster Mini, WTF????  Why is the thing such a high roller??-mini1.jpg
Old Feb 20, 2017 | 12:28 PM
drewstermalloy's Avatar
drewstermalloy
Looks like you might be able to just put the car up on jack stands, let the wheels hang, unbolt the top of the struts to drop them a little, take the spacers off, then push the struts back up to where they should be.
No idea if those tires would fit under the fenders with the stock suspension though.
Maybe it's just the angle of the picture, but it looks like someone did the joey mod on your headlights and didn't put them back in the correct position. They're a little misaligned with the chrome ring.
Old Feb 20, 2017 | 12:54 PM
thebombardier
Nah the whole hood's out of whack. Looks like a front end crash and some "close enough" body work. Mine's the same way.
Old Feb 20, 2017 | 01:08 PM
drewstermalloy
You're right, I didn't notice the mismatch between the hood and the wheel arch/fender and up by the windshield.
Old Feb 20, 2017 | 05:52 PM
GeneralSpecific's Avatar
GeneralSpecific
Tortoise? Nahh... Needs some Tonka Truck decals. I like it!
If you do take them out, may want to get an alignment like you mentioned about the suspension geometry.
Old Feb 21, 2017 | 05:35 AM
Lt. Dan's Avatar
Lt. Dan
Pfft, toss on some BFG A/T's and a lightbar... Embrace the Monster Mini!!!
Old Feb 21, 2017 | 06:36 AM
iwashmycar's Avatar
iwashmycar
x2...some beefier tires would be sweet.
The spacer kit would be very very easy to remove. Strut removal on a R56 is total cake to do.
Old Feb 21, 2017 | 07:12 AM
Grip Grip's Avatar
Grip Grip
I'm really conflicted on what to do with this Mini. I'm really temped to drop it back down and install some low profile tires, but I might just leave it alone and flip it. Regardless, I've got a good bit of repairs/maintenance work to do on it first. It's got a leaky oil filter housing and VC. I've ordered gaskets, but I'm tempted to install a catless DP and new oil feed line while I'm in there. I plan to start stripping it down tonight.
Hey, I might just bulldog it!
Old Feb 21, 2017 | 07:52 AM
N2MINI's Avatar
N2MINI
Maybe someone had been Rally Crossing it..
Old Feb 21, 2017 | 09:02 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
those would be handy for rallycross
Old Feb 21, 2017 | 10:33 AM
Lt. Dan's Avatar
Lt. Dan
Please don't
Old Feb 21, 2017 | 07:23 PM
GeneralSpecific
I have a vinyl cutter... I can cut out some Tonka Truck stickers for you!
Old Feb 23, 2017 | 05:08 AM
Not too many r56 models with a lift kit, seen more on the R60 and R61. I guess it's good for rally cross or it you were off roading or going to D squared version MINI. But other than that most people lower.
https://www.northamericanmotoring.co...l-special.html
Video:
Old Feb 23, 2017 | 05:25 AM
MiniToBe's Avatar
MiniToBe
if you dont want the lift kit, consider selling then to me
