R56 greetings all. new to us 08 MCS
Old Aug 26, 2016 | 04:21 PM
sloppyjoe999's Avatar
sloppyjoe999
so i had a small boat for sale and i traded the previous owner of this 08 MCS straight across. it is a 105k mile car. no squeaks, rattles etc. car has a new thermo housing and pipe to pump.
first thing i did was change oil and plugs, as i do with any vehicle i take on.
it appears it will need a turbo feed line swap. this looks like a easy enough task to take on. water pump is dry. most of the engine block is free from oil save for the front of the engine where drips of oil from the turbo feed line appear to have got on metal bits.
what have i got myself into here? with this sort of miles what is likely to need TLC and what has likely been replaced or swapped to new along the way?
overall the car is stock save for a ALTA intake. everything else is stock. my wife wants me to just do a quick sell on the car and flip it, but after a little bit of use i am really enjoying the heck out of this little burner. i restore old italian cars and those are very easy to work on and build, this seems like a well built little car, but very cramped under the hood. it appears nothing is easy to get at.
id like to upgrade the oil lines on the turbo, install a larger IC and do a nice exhaust. nothing crazy loud, but something that breathes easier. and enjoy it as best i can.
help, wisdom and guidance is much appreciated.
cheers
joe
Old Aug 26, 2016 | 04:36 PM
pfarinelli's Avatar
pfarinelli
Originally Posted by sloppyjoe999
so i had a small boat for sale and i traded the previous owner of this 08 MCS straight across. it is a 105k mile car. no squeaks, rattles etc. car has a new thermo housing and pipe to pump. first thing i did was change oil and plugs, as i do with any vehicle i take on. it appears it will need a turbo feed line swap. this looks like a easy enough task to take on. water pump is dry. most of the engine block is free from oil save for the front of the engine where drips of oil from the turbo feed line appear to have got on metal bits. what have i got myself into here? with this sort of miles what is likely to need TLC and what has likely been replaced or swapped to new along the way? overall the car is stock save for a ALTA intake. everything else is stock. my wife wants me to just do a quick sell on the car and flip it, but after a little bit of use i am really enjoying the heck out of this little burner. i restore old italian cars and those are very easy to work on and build, this seems like a well built little car, but very cramped under the hood. it appears nothing is easy to get at. id like to upgrade the oil lines on the turbo, install a larger IC and do a nice exhaust. nothing crazy loud, but something that breathes easier. and enjoy it as best i can. help, wisdom and guidance is much appreciated. cheers joe
You wouldn't have an X 1/9 laying around, would you?
Old Aug 26, 2016 | 04:39 PM
sloppyjoe999
Not at the moment. Sorry
Old Aug 26, 2016 | 05:12 PM
Mini Mania's Avatar
Welcome to NAM! Beautiful car, know what you mean about enjoying the heck out of them.
There are all kinds of articles and free application guides on our website for service, maintenance, accessories and upgrades which should help. Please feel free to ask any questions!
Here is some info on the turbo and parts:
http://new.minimania.com/Search_Resu...20line/default
water pump application guide:
http://new.minimania.com/Mini_Cooper...lication_Guide
intercooler and installation video:
http://new.minimania.com/Intercooler...e_Upgrade_Kits for Forge and Wagner:
http://new.minimania.com/MINI_Cooper...n_Instructions
http://new.minimania.com/MINI_Cooper...rade_by_Wagner
Hope this helps!
Old Aug 26, 2016 | 05:15 PM
sloppyjoe999
Hope this helps!
Like a mini gold mine of info. Thanks for that! I've spent all my time building old alfa romeos and a Ferrari the last few years, this is the newest car I've had to wrench on. Only thing that freaks me out is the gigantic lack of accessibility to major working components
Old Aug 26, 2016 | 06:11 PM
AZdsrt's Avatar
AZdsrt
I actually had one back in the mid 70s. Was a piece of junk, but was a good looking car..
Old Aug 26, 2016 | 08:41 PM
pfarinelli's Avatar
pfarinelli
I loved the 2 I had
Old Aug 26, 2016 | 08:46 PM
sloppyjoe999
All the Italian stuff from that Era was built like crap. But when it ran right nothing was better fun or looks wise
Old Aug 27, 2016 | 09:52 AM
oldbrokenwind's Avatar
oldbrokenwind
Long time ago --- late '60's, I had a friend with an Iso. Haven't seen any others since then, have you? Love to get my hands on one.
Take the wife's advice and flip it. If you're hooked on Mini's, hold out for at least an N18 engine version, or newer.
Old Aug 27, 2016 | 01:48 PM
sloppyjoe999
Why is that? I'm new to them, so I'm not fully up on what constitutes a good gen from a better gen engine, platform etc
Old Aug 27, 2016 | 04:13 PM
oldbrokenwind
N14 is gen 2 only. N18 is late gen 2 and into gen 3, I think --- not sure when or if it stopped. A good gen 1 is also a worthwhile investment.
N14 chronic problems consists of at least ---
Timing chain / tensioner - loses tension
High Pressure Fuel Pump - loses pressure
Aux water pump (for the turbo) - fire hazard
Water pump - leaks
Thermostat housing - leaks
Valve cover / PCV - PCV malfunctions / cover leaks
Turbo oil feed hose - clogs / leaks
There are other issues often reported, but these are the most common.
Mini dealer might be able to tell you about service history --- whether or not these items have been replaced. If you intend to do your own servicing, a Bentley service manual is a "must-have" item. And be prepared to buy "special tools", regardless of gen #.
I agree, they are a blast to drive. A larger IC and nice exhaust would be a good investment for any gen --- anything to improve breathing.
Old Aug 29, 2016 | 01:08 PM
Mini Mania's Avatar
Model Designations
Here is a breakdown of the years, models, engines, etc.:
http://new.minimania.com/MINI_model_designations
Old Aug 29, 2016 | 02:41 PM
ColoCoug's Avatar
ColoCoug
I had a 1958 Fiat Spyder for more than 40 years - my high school graduation car. Easy to work on, but I got part-way through a restoration and gave up - sold it to a gent in Denver for about 10x what my dad paid for it in 1968.
This is a factory promo shot - Italian cars are FUN!!
1958 Fiat 1200 Spyder (Transformabile).
My daughter's 2011 Minicooper S is much faster, but much harder to work on. There's no room to work under the hood on anything today...it's a pain.
Old Aug 30, 2016 | 03:59 PM
sloppyjoe999
this is our little Alfa we did a ground up on. engine, interior, body and paint all done in our garage at home.
this one is a keeper.
DRoc7822
Feb 11, 2017 08:39 AM
Hoover23
Mar 22, 2016 07:59 AM
MINIMIKO
Mar 21, 2016 11:01 AM
Car Care Products
Mar 17, 2016 03:35 PM
Doc Pain
Mar 14, 2016 09:01 AM
