R56 AC climate control
Old Jun 26, 2016 | 04:03 PM
MNMLST's Avatar
MNMLST
AC climate control
The AC compressor draws a lot of power from the engine. I'd like to know if this can be minimized through the use of climate control. So, which of the of the following statements is TRUE about the MINI's automatic AC climate control:
A: The compressor runs until the thermostat temperature is reached. The fan will continue to run, circulating cold air in the cabin. When air temperature rises above the setting the compressor runs again, continuing the cycle to maintain the desired air temperature.
B: The compressor runs at full capacity until the thermostat temperature is reached, after which it runs at minimum capacity to maintain the temperature.
C: As long the AC indicator is green, the compressor is running.
Thanks in advanced!
quickcoop
Dec 4, 2020 09:05 AM
Ygritte
Jan 22, 2019 06:48 PM
quickcoop
Sep 21, 2018 03:40 PM
Eurothrasher
May 18, 2016 08:09 AM
cjsdad
R60/R61 Stock Problems/Issues
Mar 19, 2016 10:10 PM
