R56 Engine not at full power
Old May 21, 2016 | 03:22 PM
ClubDumpster's Avatar
ClubDumpster
I have a 07 Hatchback S. Got a light that said engine can't operate at full power. I got the warranty for the timing chain tensioner when I bought the car 2 years back. Any advice for what it could be? If it's the same thing will I still need to pay or could it be "grandfathered" in?
Old May 21, 2016 | 03:44 PM
ZippyNH's Avatar
ZippyNH
Till the codes are read....nobody knows.
Timing chain issues usually have warnings....a diesel sound or other sounds...but many issues can cause the "full power is not available" warning....
Old May 21, 2016 | 04:05 PM
ClubDumpster
Knock Sensor 1 circuit low input
Old May 21, 2016 | 04:20 PM
ZippyNH's Avatar
ZippyNH
You will have to check to see what the warrenty you bought covers, and make sure it is still in effect....
If you are lucky it is a simple sensor or wiring issue.
I am by no means an expert on the gen2 cars...but unless it is making odd sounds....it would not appear to be a timing chain issue.
Old May 21, 2016 | 05:06 PM
cerenkov's Avatar
cerenkov
With "low input" error, I would suspect a bad sensor or wire.
Old May 21, 2016 | 07:34 PM
ClubDumpster
I'm trying to find a diagram or way to test the sensor online and can't find anything. Anyone have any instructions?
Old May 21, 2016 | 07:50 PM
Semaphore's Avatar
Semaphore
When does it come on? Mine came on when I would get on it under boost and then let off the gas. I suspect mine was from carbon build up but I burned a valve after 6 months of intermittent CEL. If you suspect that; clean the intake valves and save some money!! I'm into my rebuild now at $650.00 not including head rebuild, which I don't have a quote yet... Hope this helps.
Old May 22, 2016 | 05:30 AM
ClubDumpster
It came on after I washed my car. I just started driving it when I felt it then the light came on. I'm hoping the sensor is just bad
Old May 23, 2016 | 09:54 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
P0327 Knock Sensor 1 Circuit Low (Bank 1 or Single Sensor)
http://www.pelicanparts.com/catalog/..._pg2.htm#item8
To test the sensor, you will have to gain access to the sensor, red arrow below. The reference voltage wire should read around 2.5 volts, for a good sensor. We go over how to test it in our tech aritcle under MINI > tech info (tab at top) > R56 articles > Fuel Injection > Knock sensor Replacing.
888.280.7799 | 6am - 5pm PST
angeltrain31
Jun 12, 2016 05:58 AM
Repeat_Offender
May 11, 2016 04:44 AM
thelawson
Apr 13, 2016 11:04 AM
dn09MCS
Mar 14, 2016 08:50 AM
alexs3d2
Mar 14, 2016 08:35 AM
