R56 Diverter Valve from GP2 on MCS
Old May 16, 2016 | 06:50 PM
Bryan Lo's Avatar
Bryan Lo
Hey guys,
Just wondering if the DV from a GP2 would be an upgrade for a 2010 MCS. It's a straight swap as far as I know, but does anyone know if the DV from the GP2 is any different/better than the one in the 2010 MCS?
Thanks!
Old May 18, 2016 | 02:07 PM
Its the same DV for the GP2 as its for the MINI Cooper S, now the newest design stock DV would be an upgrade over the -2010 which might have the older design. Pull the old DV out and compare to one listed.
Newest stock DV design from MINI. 11658636606
https://www.northamericanmotoring.co...e-the-bov.html
Old May 21, 2016 | 06:41 AM
BigBoost's Avatar
BigBoost
have you looked to see if forge motorsports has a upgraded DV for you're gp! i know they do for the n14 and n18 but not to hip on whats in the gp2
Old May 21, 2016 | 09:06 AM
MarioKart's Avatar
MarioKart
Vendor
It's pretty much the same DV. You could either add the $20 stiffer Alta Spring to your DV or go with the Forge DV system, I use it in my GP2 and it sounds good too, makes more of a whooshing sound.
mQubed Motorsport, Manic Tuning Dealer
Old May 21, 2016 | 04:01 PM
Bryan Lo's Avatar
Bryan Lo
Thank you all for the replies.
I've swapped in the DV from a GP2 and upon comparing, this DV is indeed slightly different from the original one on my 2010 MCS. Not really sure it'd be a performance upgrade though as they're only very slightly different; the springs felt exactly the same between the two.
I did find a crack in the plastic on the original 2010 DV though so I guess it was due for a replacement anyways.
Between the new DV and replacing a cracked turbo inlet pipe with another OEM one, the car somehow felt less powerful to me (maybe less boosty and more linear?). Go figure.
Old May 24, 2016 | 08:32 AM
Welcome, yea the older pre 2010 and 2007-2009 design tend to crack on the diaphragm.
Calyman24
May 22, 2016 01:45 PM
Scottke
May 19, 2016 03:28 AM
NullUnit60
May 15, 2016 05:44 PM
pehrlich
May 14, 2016 08:34 PM
yeahyouknwit
R55 :: Clubman Talk (2008+)
May 10, 2016 04:35 PM
