R55 2010 clubman problems, fix or sell?
Hey guys i have a 2010 clubman that is now throwing the p3091 code. Did some research and found that the hpfp is usually the problem. My mini does not have any problem starting and stalling but will sometimes run rough while at idle and throw the yellow engine icon on the tach. Im debating weather I should replace it or sell the mini since the hpfp costs so much. Is there anything else that could cause the p3091 other than the hpfp? Any advice would be a great help.
The HPFP is covered under warranty for 10 years and 120,000 miles by the dealership, so definitely fix, for free! Check out post 3 here. Might help you make your decision to keep or sell: https://www.northamericanmotoring.co...-70-000-a.html
P3091 Fuel Rail Pressure Pressure-Rate- Controlled, Fallen Below Minimum Pressure
Is it a Clubman Base or Clubman S? The extended warranty does say only select models from 2007-2009, but I've even seen 2010 N14's and there has been noted instances where dealers warrantied N18 HPFP's. This individual HERE had it replaced in their N18 due to service bulletin # 010116. Maybe give it a shot if you believe the HPFP is your issue.
888.280.7799 | 6am - 5pm PST
I work for a dealer, send me the last 7 of your VIN and I will see if you have the coverage.
hernlui
Jul 24, 2016 09:39 AM
R50/53 Tips on selling my mini
Jimmy Devaney
30
May 27, 2016 11:00 AM
