R56 N14 Rattle That is NOT the Timing Chain
Old Apr 20, 2016 | 05:34 AM
NathanMckee's Avatar
NathanMckee
Hi everyone,
So our 2009 N14 has been rattling really loudly when starting and I thought it was the timing chain. I took it to the dealership to have it replaced but they said it was not the timing chain, but it was the wastegate rattling around. It had boost fault codes that show lack of boost pressure and they are saying the wastegate actuator has failed and that is the noise I am hearing. Car has 105,000 miles on it. Chain tensioner was just recently replaced.
Has anyone else had that happen? I will be doing the turbo replacement myself but I just wanted to know if anyone else had a turbo rattle that sounds like a coin in a can that's on a paint mixer...
Old Apr 20, 2016 | 08:44 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Yes, I've seen this a few times before. If you need help, we have a turbocharger replacement article on our site that can help you with the replacement. It's under the tech info tab at the top and the last article under the R56 articles. Turbo HERE if needed.
888.280.7799 | 6am - 5pm PST
Old Apr 21, 2016 | 04:29 AM
NathanMckee
Oh trust me, I have already read that through many times. That is such a fantastic write up. The pictures help out a lot too.
Old Apr 22, 2016 | 06:13 AM
BigBoost's Avatar
BigBoost
This may sound a little wired! but have you check you're vacuum pump? i want tho the same thing ! i swap out the valve cover and the pump and it want a way!! mini does have a tech right up on how to check the pump! witch is funny < mini/bmw say's its a normal noise !!
And keep in mind the N14/n18 are noiseee power plate's from you're injector's firing to the coils fireing !!
Old Apr 22, 2016 | 06:18 AM
NathanMckee
Interesting... But the pump is fine on ours because when you pull the vac line from the waste gate actuator the noise goes away. But now I am curious about how much life is left on the vac pump... Anyone know of symptoms of one that is failing??
Old Apr 22, 2016 | 07:29 AM
PelicanParts.com
Vendor
Glad they have been helpful to you.
For the vacuum pump, some signs of it failing can be low brake booster vacuum, hard brake pedal, and brake fade during application when stopped. They can also leak oil as well.
Old Apr 22, 2016 | 07:39 AM
BigBoost's Avatar
BigBoost
pull you're vac line from the pump and see what happen's!
Old Apr 22, 2016 | 07:46 AM
NathanMckee
Glad they have been helpful to you. For the vacuum pump, some signs of it failing can be low brake booster vacuum, hard brake pedal, and brake fade during application when stopped. They can also leak oil as well.
Well that is good news because I do not have those problems!
angeltrain31
Jun 12, 2016 05:58 AM
Repeat_Offender
May 11, 2016 04:44 AM
tonymtorres47@hotmail.com
Mar 30, 2016 08:56 AM
themarques
Mar 30, 2016 07:05 AM
Hoover23
Mar 22, 2016 07:59 AM
