R56 07 Mini S new to these issues
Old Nov 2, 2015 | 01:56 PM
Jesse Seward's Avatar
Jesse Seward
We bought an 07 about 5 or 6 months ago and I am sure that the questions that I am going to ask have been gone over but here the question/problems.
96,000 miles
-Oil leak
-P115C code
-Air Bag light
-Some what of a ticking noise from engine bay
That is all I have for now. How do I fix these, what do I look for, What do I need to do with these type of miles?
Thanks in advance for the help.
Old Nov 3, 2015 | 06:09 AM
SPRINTCARS's Avatar
SPRINTCARS
Where's the oil leak ?
115c code is most likely a vacuum leak and its related to oil leak that's most likely the valve cover. It's easy as hell to fix.
Air bag, someone else has gotta chime in about that. Maybe pelican or Esc can tell ya.
The ticking noise, depends, but they are not the quietest motors that's for sure.
Does it do it at start up ?
It always does it ?
How loud ?
There is a quick short fix for it if you think it's the timing chain without doing the entire job.
Old Nov 3, 2015 | 11:23 AM
-Oil leak ; where ?
Aibag , might be if you removed the seat or someone did in the past and did not unhook the battery, MINI dealership or some shops and clear the code.
P115C code : clean the MAF
Some what of a ticking noise from engine bay : make sure your oil is not low. And also check to see if there is timing chain noise ( more of a rattle ) is there: on the passenger side.
Timing chain.
https://www.northamericanmotoring.co...ce-please.html
Old Nov 6, 2015 | 09:25 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
First, can you post a video of the tick noise you describe. Second, P115C is Mass air volume flow "A" too low. Do you have an aftermarket intake? I'd start with cleaning it with MAF specific cleaner and clear the code. See if it comes back after you clean it up. Some good info in this NAM thread here. As for the oil leak, we have a great oil leak diagnosis DIY here that can help you possibly trace down your cause. Let me know if you have any other questions or need further assistance.
888.280.7799 | 6am - 5pm PST
Jack Lee
Dec 10, 2023 11:05 AM
RHcoopers
Mar 29, 2016 08:42 AM
midnightblackjcw
Dec 7, 2015 03:04 PM
miniaway
Oct 16, 2015 01:03 PM
Bhouston13
Oct 7, 2015 09:44 AM
