R56 Brake Pad Wear Sensor Damage
Old Apr 18, 2015 | 09:42 AM
rustledjimmies's Avatar
rustledjimmies
Hi everyone,
I just finished replacing front/rear brake pads and rotors and noticed there was some damage to the brake wear sensor. I didn't have new ones to replace at the time so I put it back on anyways hoping the brake light will disappear. Unfortunately the brake light won't turn off.
So my plan is to purchase and install new brake pad sensors but I hear this light won't cancel itself out even after I put new sensors on and I need a special scan tool to reset this light, is this correct?
Old Apr 18, 2015 | 09:51 AM
mtechnik2's Avatar
mtechnik2
Do a CBS data reset through the kombi.
Old Apr 18, 2015 | 09:57 AM
rustledjimmies
sorry could you say that in laymans terms? im fairly new to the mini platform so i dont know any of the lingo or acrynms associated with it hahaha thanks!
Old Apr 18, 2015 | 11:28 AM
yashmack's Avatar
yashmack
mine was damaged too, did yours break on the back of the sensor? the opposite side from what would touch the rotor and wear out...
Old Apr 18, 2015 | 11:29 AM
yashmack's Avatar
yashmack
this is what i found on how to reset the error
Ive heard there is another method but havent found info on it
Old Apr 18, 2015 | 03:22 PM
pokeyjoe's Avatar
pokeyjoe
Veteran: Navy
For future reference, the wear sensor gets ground down with the pad. You have to replace them to get rid of the warning. They are also pretty much toast from the heat anyway.
Old Apr 18, 2015 | 04:40 PM
Capt_bj's Avatar
Capt_bj
A GEN1 nor GEN2 require a trip to the dealer to clear a brake wear alert . . .
the GEN2 has TWO systems watching pad wear.
first is a simple miles counter like the oil change one. When this one comes active you can simply go thru the stalk and reset the miles if you want to ignore ..... it knows NOTHING about pad condition (but you'd be WISE to CHECK pad condition at this time)
second is the pad wear sensor which works by the sensor being in contact with the rotor and wearing down with the pads as mentioned above. When the pads get X thin, the sensor has worn to X thin and in the process breaks a wire which results in an 'alert' on the dash.
You can not clear THIS one until you reconnect the circuit break caused by the open wire. There are 2 ways to do this:
1) replace the worn sensor
2) jumper out the sensor by clipping the sensor off and connecting the two ends of the leads together. (search my posts for instructions)
a GEN2 recognises the new sensor with no special action either way
{for a GEN1 to recog' a new sensor turn the key to position one (on but not start) and the light should clear in under 60 seconds}
thebordella
Aug 31, 2015 01:37 PM
jpgwinn24
Tires, Wheels, & Brakes
Aug 23, 2015 02:53 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
