R56 Replacement Key
Old Aug 18, 2015 | 07:22 AM
  #26
michaelsuoo's Avatar
michaelsuoo
Will,
Thanks for the info. Much appreciated!
Old Sep 14, 2015 | 11:27 AM
  #27
WillShootPhotos's Avatar
WillShootPhotos
Originally Posted by ggrimm01
It was around that price w/o comfort access. I have comfort access so mine was more. If you click on the links in the previous post you can get a exact cost. There are 2 items to order. The key fob and passive key. Once you order check the email updates so you can send the info requested from minipartstore. However make sure you change the make model to match your year, make model.
Did you have to have a local dealership code the new fob to your mini for the comfort features to work?
I just ordered a fob/slide-in-key from TheMINIPartStore and got the key/fob very quickly, but then found out that the comfort programming would be about an hour at the dealership.
Do you think a home coding/maint app like "Carly" would be able to do this?
Thanks in advance,
- Will
Old Sep 14, 2015 | 11:42 AM
  #28
ggrimm01's Avatar
ggrimm01
Programing.
Thanks in advance,
- Will
I did my own. I have an ICOM a2 and the software. You may be able to do it with other software. However the software will need to pull info from several Assemblies.
Old Sep 14, 2015 | 12:34 PM
  #29
WillShootPhotos
Gotcha - thanks... I'm deep in the process of deciding how much I want to spend on a device/software... not sure if I'll use this for much other than this one "complex" task... most other tweaks will (prob) be minor.
Thanks!
- Will
Old Sep 25, 2015 | 04:05 PM
  #30
I_drive_slow's Avatar
I_drive_slow
Just got the key in the mail from bmwminiparts store. Reasonable price and really fast shipping time! Thank you very much!
Old Aug 7, 2016 | 09:09 AM
  #31
yeahdog31's Avatar
yeahdog31
reprogram?
Just curious (I realize it's an old thread) --
Did you have to do any reprogramming once your new replacement key arrived? Or by supplying VIN, etc, did the new key immediately work directly out of the box?
Old Aug 7, 2016 | 09:16 AM
  #32
michaelsuoo
I just received my order a few weeks ago. They key works right out of the box. No programming is needed as long as you provide the correct VIN # when ordering. The Comfort Access is a different story. A trip to Dealer is needed for that.
Old Aug 7, 2016 | 11:16 AM
  #33
I_drive_slow
Worked right out of the box.
StillK
R55 :: Clubman Talk (2008+)
Dec 7, 2022 08:19 AM
polotska
Aug 23, 2015 03:03 PM
coachvminis
Aug 17, 2015 01:42 PM
speedbird_1
Aug 15, 2015 04:44 PM
skippermini
Aug 13, 2015 06:13 AM
