R56 Obd II Reader
Old Feb 24, 2015 | 07:21 AM
pfarinelli's Avatar
pfarinelli
Obd II Reader
Just purchased one of these devices. I want to get an app for my phone that shows what is going on with the engine. Which app do you use? I saw the torque app and a few others. I have an iPhone 6 plus
Thanks for your help.
Old Feb 24, 2015 | 07:28 AM
texaswadefish's Avatar
texaswadefish
I use Dash Command, it's a free download and offers a ton of info.
Old Feb 24, 2015 | 07:39 AM
Helix13mini's Avatar
Helix13mini
I don't know if there are any apps that recognize proprietary BMW/MINI codes. If there are, this would be an awesome setup. If not, you'd be getting very limited information. For generic OBD 2 codes, you can buy a cheap-o scanner from an auto parts store which would do the same thing. To be able to read proprietary factory codes you'd need a tool like the Bavarian Technik scan tool: a hardware/PC software setup.
Old Feb 24, 2015 | 08:00 AM
jkapinos's Avatar
jkapinos
Or use BMWhat.
Old Feb 24, 2015 | 12:57 PM
Slave to Felines's Avatar
Slave to Felines
Which device did you purchase? There are dedicated OBD2 readers that you can get--either generic ones that can read and reset some codes, or the BMW- and MINI-specific ones that can read all of the codes produced by the car.
There are also "dongles" you can plug into the OBD2 port that will also talk to your phone, either over Bluetooth or by a cable. If you have one of those, then you can use apps like Torque. Those will generally be similar to the "generic" readers above; able to read many common codes but not able to see the MINI-specific ones.
Old Feb 24, 2015 | 04:25 PM
pfarinelli's Avatar
pfarinelli
Originally Posted by Slave to Felines
Which device did you purchase? There are dedicated OBD2 readers that you can get--either generic ones that can read and reset some codes, or the BMW- and MINI-specific ones that can read all of the codes produced by the car. There are also "dongles" you can plug into the OBD2 port that will also talk to your phone, either over Bluetooth or by a cable. If you have one of those, then you can use apps like Torque. Those will generally be similar to the "generic" readers above; able to read many common codes but not able to see the MINI-specific ones.
I got a dongle the is wifi and Bluetooth for ios
PsychoRallye
21
Feb 17, 2019 06:08 AM
navybsn
Oct 5, 2018 04:42 PM
JLSM511
Feb 25, 2016 01:02 PM
Mazarin
Sep 15, 2015 08:45 AM
mtwaddle
Sep 13, 2015 08:10 PM
