R56 Creaking Clutch 2012 MCS
Hey everyone, I have a 2012 Cooper S Manual which I purchased early this year from a local MINI dealership. It's had quite a few problems already, which had fortunately all been dealt with under the factory warranty. However, there is just one niggly little issue which persists...
Basically once the car is warmed up the clutch pedal starts to feel rough/grinding whenever the pedal is pushed down or released. At first it was just the actual feel of the pedal which I noticed felt odd when the car was warm, but recently the rough feel has gotten noticeably worse and there is also a creaking sound accompanying depression and release of the clutch pedal, this sound can also be heard outside of the car.
It is a strange issue because the clutch otherwise operates completely fine and shows no signs of slippage etc. It may however be worth noting that one of the previous issues I had with the car was the ABS light failed going off which was fixed under warranty (was apparently down to faulty sensor).
I mentioned the weird feeling clutch when the ABS issue was being dealt with and the dealership could not find anything, and put it all down to the ABS issue which I was told could have caused a rough feeling clutch.
I would appreciate it if anyone has any idea what this problem might be with my clutch pedal and if this is a common issue at all with these cars.
Sorry for the long post !
I just had a new clutch components replaced along with a new flywheel and I can also hear a creaking sound accompanying depression and release of the clutch pedal. Want to know something else strange, it did not make the creaking sound before I replaced my worn out clutch and flywheel that I drove for over a year with no sounds coming from the slave cylinder and no clutch problems at all. I would first look at your main and slave cylinders before touching the clutch! The main cylinder is attached to your clutch pedal, slave cylinder is mounted on the outside of the bottom of the transmission case, since there made of plastic......
If your slave cylinder isn't operating properly it will cause stress on your clutch parts, a bad slave cylinder has been the cause for early clutch failures! If you're thinking about replacing the slave cylinder it a good idea to replace the main cylinder (attached to clutch pedal) as well because they exert great hydraulic force on one another, you then need to pressure fill and bleed your clutch/braking system. My advice pay the dealer to do it because it's a pain in the ***!
I replaced both of those bushing myself, hardest part was compressing the return spring and getting it install. By accident I found out how to get the return spring back in, it took me all day while upside down to stumble on how to get it back in. If the OP requests the trick of how to reinstall the return spring in minutes I'd be glad to help out, I was cursing all day trying to get it in.
I am just hoping to god they don't just give me the usual 'they all do that' line, only to have the clutch give out on me a few months down the road, in turn forcing me to pick up the bill for a brand new clutch
Anyone else feel free to add to this discussion, the more information I can get here, the better position I might be in not to get ripped off by the stealers!
I highly appreciate your offer to try and help me figure out how to replace the bushings on the clutch pedal. Unfortunately, I'm most likely nowhere near as mechanically inclined as you are with these cars, and since the car is still under factory warranty, I will try and recreate the issue in front of a mechanic at the MINI dealership.
Just to update this thread unfortunately Im still having problems with my clutch! :(
If any of you technical gurus could offer some expertise on my latest issue I would be forever grateful.
I'm now getting a whirring/droning sound coming from the front of the car which can be felt through the clutch pedal. Here are the symptoms:
1. The noise only appears upwards of 3k RPM's
2. Noise can be heard when the clutch is DEPRESSED (whether in neutral or in gear), and the noise can also be heard when the clutch is RELEASED but only in gear.
3. No noise at any RPM when freely revving in neutral. But as soon as clutch is depressed (still in neutral), noise comes back.
Does this sound like a bad throw out bearing?
The throw out bearing is only engaged when the clutch is depressed as far as I know - I could be totally wrong.
Wild guess - Could be a thrust bearing in the motor. Clutch depressed pushes axially on the flywheel and crankshaft. I have heard of crank walk issues on these motors though. Dunno, I'm stumped.
Sent from my Nexus using NAMotoring
R50/53 2002 R53 Creaking/Clacking
maestro39
Oct 27, 2015 02:38 PM
Colt45Magnus
Aug 13, 2015 11:18 AM
