R56 09 Hatch won't unlock
Old May 6, 2014 | 01:58 PM
Phenix360's Avatar
Phenix360
My 2009 Cooper S hatch will not unlock by double tapping the Unlock remote, however it will unlock and open by pushing the remote's Hatch Open button. Any suggestions would be appreciated.
Old May 6, 2014 | 05:13 PM
Systemlord's Avatar
Systemlord
Your supposed to hold it down on the remote, don't know why you need to double tap it.
Old May 6, 2014 | 05:21 PM
Phenix360's Avatar
Phenix360
The unlock button takes a single tap to unlock the driver door, a double tap to unlock all other doors. The double tap does not unlock the hatch. I have to use the Hatch Open button to unlock and open the hatch. Once I close it, the hatch remains locked.
Old May 6, 2014 | 05:27 PM
hsautocrosser's Avatar
hsautocrosser
It is not uncommon for the switch to fail. It requires replacement of the entire trim strip or continued use of the remote.
Old May 6, 2014 | 05:43 PM
AZdsrt's Avatar
AZdsrt
If the hatch open button works, sounds like lock switch is ok. If you have a second key fob, does it work correctly? Hitting the door open button twice on mine does release the hatch.
Old May 6, 2014 | 05:52 PM
Phenix360's Avatar
Phenix360
Both remotes work the same. Neither one will unlock the hatch unless I use the the Open Hatch button.
Old May 6, 2014 | 05:58 PM
Phenix360's Avatar
Phenix360
I fear hsautorosser is correct about needing to replace the entire trim strip. Thanks for your help.
Who sells the best priced trim?
Old May 6, 2014 | 05:59 PM
hsautocrosser
Ok, How do you know the hatch isn't unlocked when you double tap the unlock button on the remote?
Old May 6, 2014 | 06:03 PM
hsautocrosser
Cross posted. Never mind.
Old May 6, 2014 | 06:21 PM
Phenix360's Avatar
Phenix360
I know the hatch won't open because I pulled up on the hatch handle after double tapping the remote and the hatch won't open. It remained locked.
Old May 6, 2014 | 08:49 PM
hsautocrosser
Are you pressing on the rubber-covered switch under the handle to unlatch the hatch as well as pulling up on it?
Old May 7, 2014 | 06:03 PM
Namotuman's Avatar
Namotuman
I had the same problem with my 2011 MCS (I bought it used). I thought wtf, why won't my hatch unlock with the rest of the doors using the fob. I just got used to using the fob to open the hatch figuring it was the norm. Then I went for a maintenance visit at the dealer and asked them about it. It turned out the handle switch was bad and had to be replaced. IF unlocked, just squeezing/depressing the rubber pad should properly pop the hatch.
Fordgt4
Oct 10, 2015 10:42 AM
martinb
Oct 7, 2015 05:00 PM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
silence2-38554
Sep 28, 2015 12:19 PM
TifosinDel
Sep 28, 2015 10:45 AM
