R56 R56 Buzzing noise
Old Mar 7, 2014 | 09:50 AM
os20klee's Avatar
os20klee
R56 Buzzing noise
Hello.I started to hear some kind of buzzing noise coming from door (Driver side). Anybody have a clue where it is actually coming from? How hard is it to remove the door panel? Thanks.
Old Mar 7, 2014 | 10:15 AM
julzism's Avatar
julzism
Is it coming from the driverside toward the rear of the car?
Old Mar 7, 2014 | 10:55 AM
os20klee's Avatar
os20klee
It is coming from the front side.
Old Mar 7, 2014 | 11:03 AM
SoCalledFriend's Avatar
SoCalledFriend
Not sure if this is your problem or not, but I had a buzzing sound as well (as soon as I got the car) and I figured out it was coming from the seat belt anchor right behind the drivers seat. All I did was rest the corner of the rear floor mat up on top of where the seat belt bolts into the floor, and problem solved.
Old Mar 10, 2014 | 11:51 AM
os20klee's Avatar
os20klee
Mine seems like it is coming from the same place you mentioned above. Simply when I put my hand over it, i don't hear the buzzing sound. Can you explain again how you fixed yours? I don't really understand what you meant by "rest the corner of the rear floor mat up on top of where the seat belt bolts into the floor". Thanks.
Old Mar 10, 2014 | 12:18 PM
SoCalledFriend
Sure.
The first picture is the floor mat with normal placement. The second picture is with the corner of the floor mat resting on top of the connecting point of the seat belt mount.
Attached Thumbnails R56 Buzzing noise-20140310_121218.jpg   R56 Buzzing noise-20140310_121201.jpg
Old Mar 10, 2014 | 01:55 PM
os20klee's Avatar
os20klee
Thanks for the pictures. I will try that today. That seems to be a very easy fix^^
Old Mar 10, 2014 | 02:01 PM
Wrecks's Avatar
Wrecks
I have a buzz noise only when the radio is turned up. If i put my hand on the door handle it goes away. I have yet to address it.
Old Mar 11, 2014 | 11:31 AM
os20klee's Avatar
os20klee
Originally Posted by SoCalledFriend
Sure.
I tried your way but it still buzz. I think it is coming from the actual plastic piece behind the seat belt anchor....
Melvinyip
Apr 17, 2020 09:28 AM
Spank
11
Apr 9, 2020 02:23 PM
LordOfTheFlies
Oct 19, 2015 05:02 PM
coachvminis
Aug 25, 2015 06:58 AM
patrioticmini
Aug 20, 2015 10:54 AM
