R56 No heat unless on the throttle.
Old Dec 12, 2013 | 07:36 AM
BJM's Avatar
BJM
Hello everyone. Last week my check engine light came on. Everything seemed to be okay. I turned a blind eye to it for the moment as I have my last semester's worth of finals to worry about. Between finals and work, I don't have time to play around at a Mini dealership, that's 50 miles away, for a bogus censor or something.
Anyway, fast forward to two days ago. I'm parked at a stop light and all of a sudden my car just starts blowing freezing cold air at me. I pushed a few buttons (fan speed, temp, auto, etc..) and it went away. Well, the problem persists. I only get heat when on the throttle and when the engine is revving higher than 2000 rpm.
I called my mini dealership and the first day they can get me in is Dec 23, 11 days from now. I get that it's first come first serve, but it's winter (single digits with wind chill this morning) in Connecticut. I have a 40 mile commute each day, and spend at least 20-30 minutes in stop-and-go traffic. For those 20-30 minutes I am sitting in a refrigerator. I think it's crap that I can't get in any earlier than that AND they don't have a loaner car for me... but that's a different rant.
I've been searching the boards (searching is difficult here because of all the sub forums) and have seen several complaints about having no heat. I haven't seen any that really match what I am experiencing. I think my coolant may be low, but I'm not mechanic, and I don't see any evidence of a leak in the snow on my driveway.
It looks low to me, and if there's a leak I am obviously going to schedule an appointment, but at least I'll have heat until then. The manual advised that certain coolants are not compatible in a Mini. What should I use?
Thanks for your time.
Old Dec 12, 2013 | 07:57 AM
You might have a leak at the thermostat housing.
What year is your R56 Cooper ( Non S) ? 11537534521 for the thermostat housing up to 2/2013 ( which is in the linked post ) , then need the little adapter cable ( 12517646145 ) for the Cooper (non S) thermostat housing. On the 2/2013+ they went to 11537647751 part, which does not the additional adapter lead.
You can check out this thread on the no heat. Looks like you have a leak and here are some common locations. Here is the link w/ info and coolant to use, since you have the MINI Coolant, Blueish color.
https://www.northamericanmotoring.co...8-no-heat.html
You don't want to overheat and ruin your engine.
Old Dec 12, 2013 | 08:10 AM
BJM's Avatar
BJM
Thanks for the reply. Not sure how I missed that thread. I appreciate the help.
Old Dec 12, 2013 | 08:42 AM
JcarrollWS6's Avatar
JcarrollWS6
Definately a coolant leak. Do you hear any water rushing around after tapping the gas from idle? Air in the coolant creates an audible tirbulace when rushing thorough the heater core near the firewall/dash.
Old Dec 12, 2013 | 09:29 AM
BJM's Avatar
BJM
Not that I noticed. I may have heard it and just not registered the noise. I just bought a gallon of coolant from BMW, same stuff from what I gather (sorry ECS, I don't have time to to wait on shipping, especially with the holiday mail rush). I just topped her off and the engine immediately changed its tone. It's warming up in the driveway now. I'm going to go out in a few minutes, after I send my cars salesman an email, and see if it's toasty or not.
Old Dec 12, 2013 | 10:15 AM
dmyer's Avatar
dmyer
It is British Car throw back day! An authentic Vintage British car experience.... All my MG's and Triumphs only had heat when it was hot outside!
I am betting on what those guys said.... to make heat you need "Hot Water" and you probably do not have enough in the system. You need to get that fixed ASAP.
Old Dec 12, 2013 | 12:15 PM
Systemlord's Avatar
Systemlord
A couple of months ago I spotted a water puddle on the ground making a quick stop at my house and it turned out to be coolant. I traced it to the thermostat housing, it was squirting out of the base of the thermostat housing. It tends to leak on top of the tranny housing dripping down backwards to the bottom of the tranny. My reservoir was almost drained completely. Glad I caught it before my Check Engine light came on!
Old Dec 12, 2013 | 07:22 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
This really sounds like a Thermostat, we have been seeing a ton of them fail at a rate of at least one a week in the shop.
Old Dec 12, 2013 | 07:31 PM
micromini234's Avatar
micromini234
Being from ct and student I offer my help to you, but it sounds like your pretty far away from where I am located.
Old Dec 13, 2013 | 06:55 PM
Systemlord's Avatar
Systemlord
Way why doesn't anyone manufacturer an aluminum version of the thermostat housing? There's money to be made here no doubt! Even though I replaced mine a few months ago I would jump at the opportunity to install an aluminum version and I'm sure many more would as well! I could see an aluminum version lasting much longer.
Old Dec 13, 2013 | 07:04 PM
vetsvette's Avatar
vetsvette
Moderator
+1
Old Dec 13, 2013 | 07:18 PM
Systemlord's Avatar
Systemlord
Originally Posted by vetsvette
+1
How many times have you replaced your thermostat housing? At least twice right?
Old Dec 13, 2013 | 08:38 PM
vetsvette's Avatar
vetsvette
Moderator
From the maintenance history I got with the car, only once. . . . so far.
Old Dec 14, 2013 | 12:49 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
I know I would buy one..along with a few friends of mine... I cant recall ever messing around with thermostats and housings as much as I have on the MINIs..
Old Dec 17, 2013 | 02:52 PM
BJM's Avatar
BJM
Just got a call from the Mini dealership. Needs a new water pump at 25.5k miles. Fantastic!
dgamblin
Jan 2, 2021 02:57 PM
Colt45Magnus
Oct 1, 2015 04:08 PM
Tires, Wheels & Brakes
Oct 1, 2015 12:18 PM
potterstein
Oct 1, 2015 07:10 AM
M7Speed
Oct 1, 2015 07:05 AM
