R56 Bulb warning light on
I have an exterior bulb warning light on, but all exterior lights are working except that the headlights will not turn off. Any help will be appreciated.
Thanks in advance
Ric
Thanks in advance
Ric
I have the same problem. My warning light says a fog light is out. I replaced both lights even though they both worked, mostly to verify good contact.
I took it to the dealer just before my warranty expired. The odometer read 49960 so I wanted the problem documented. I was told I had to leave the car right then. Once the odometer read 50,001 they would not touch it under warranty. I couldn't do without my vehicle right then, so the warranty expired.
I had an independent shop look at the faulty warning light and they said it would be expensive or really expensive to repair depending on how long it took to chase down a bad connection, or replace an ECM. So now I just live with a faulty error light.
I am not at all impressed with BMW's customer service.
I do not think I could buy another BMW or Mini even though I love the car.
Check the lights over the license plate. I had the warning for a bit, then found that those were both burned out.
Have fun,
Mike
Have fun,
Mike
Sad that a dealer wouldn't step up for you. I would call Mini NA and complain. They might be able to help you out.
OP: You may have a bulb failing intermittently. It happened with my better-half's Justa. One of the parking lights eventually quit for good. I replaced it, and the bulb warning went away. Just keep checking all the lights periodically.
I had license lights out recently and my car spent two days at the dealer as the "reprogrammed" it. Lights work now. I had no bulb out indicator when one bulb was burned out. When bulb out indicator came on I found both new bulbs wouldn't work. The reprogramming made the same bulbs work. Very confusing........I miss fuses and two wire systems.
I agree with twrxxa above in regards his comments on warranty coverage noted prior to expiration.
Lschneider
Aug 21, 2015 02:21 AM
I_drive_slow
Aug 18, 2015 10:47 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
