R56 Stock Antenna Alternatives?
Old Jul 19, 2013 | 12:10 PM
Leader's Avatar
Leader
I replaced my stock antenna with a stubby from CravenSpeed.
Unfortunately, the AM reception is degraded significantly with the shorter antenna, which makes sense.
Are there any alternatives between the four-inch stubby and the long stock antenna? I see lots of cars with eight or nine-inch antennas, which should offer better AM reception. Question is - would any of them fit?
Old Jul 19, 2013 | 12:16 PM
daddyandmadi's Avatar
daddyandmadi
I replaced mine with a VW antenna that screwed right into the base. 3 different lengths. 6" and no issues with AM reception. Try a VW parts guy as they are more plentiful. Mine was concept1 in Calgary.
Old Jul 19, 2013 | 01:24 PM
sasquatch's Avatar
sasquatch
I saw someone put a Honda s2000 antenna on theirs so that one might fit as well.
Old Jul 19, 2013 | 01:53 PM
aldito2's Avatar
aldito2
ebay antenna for like $9 free shipping from china 1.25" inch or something like that. Radio sounds fine and it was cheapest i found.
http://www.ebay.com/itm/1-5-Black-Short-Stubby-Aerial-Antenna-Mast-fit-most-Mini-/231017496030?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACooper&hash=item35c9b73dde&vxp=mtr
i think that's exact one I bought (check if fits, but I think it was that one)
Old Jul 19, 2013 | 01:54 PM
Leader's Avatar
Leader
VWs have lots of different antennas. Which VW model antenna fits the MINI base?
I think the S2000 antenna was a match for the first gen MINIs (smaller diameter socket), but not the R56's larger receiver. I could be wrong.
AM reception needs "length" - that ultra-short stubby would be even worse than a 4-inch shorty.
Old Jul 19, 2013 | 05:50 PM
S_Banks's Avatar
S_Banks
I got the CravenSpeed Stubby, here in the greater Seattle area no loss of power... but I listen solely to FM.
Old Nov 7, 2013 | 08:15 AM
sandplasma's Avatar
sandplasma
The Mini Cooper uses the rear window for FM antenna. The stubby will only affect AM reception.
Old Nov 7, 2013 | 09:36 AM
kyoo's Avatar
kyoo
is there anything like a screw on plug for the antenna base?
Old Nov 7, 2013 | 09:47 AM
ASKtheteach's Avatar
ASKtheteach
That's something I would like to find. I may have to troll the hardware aisle at Home Depot to see if there's something that will fit. It could be painted black to match.
Old Nov 7, 2013 | 10:13 AM
kyoo's Avatar
kyoo
Please post if you find it! I don't know what kind of repercussions having a metal piece there would be, so maybe plastic/nylon etc may be an option
Old Nov 7, 2013 | 10:16 AM
1drummer's Avatar
1drummer
The antenna is only for A.M.??
Old Nov 7, 2013 | 10:26 AM
chimivee's Avatar
chimivee
I have the CravenSpeed and FM reception degraded. However, it is only noticeable on certain stations and in areas where the signal is already marginal.
There is about a 2 mile stretch on my commute during which I'd get static on certain stations with the stock antenna. With the CravenSpeed, the reception drops out completely. If your station reception is normally strong, the stubby antenna will likely have little negative effect and you'd never know.
Old Nov 7, 2013 | 10:32 AM
vetsvette's Avatar
vetsvette
Moderator
My CS stubby works fine, but then again, I have never tried to listen to an AM station.
Old Nov 7, 2013 | 11:19 AM
sandplasma's Avatar
sandplasma
You mean to get rid of the antenna or the base? I saw a few tiny stubby antennae that were around 1.5 inches on ebay. Pretty much gets rid of it but the base will still be there.
If you mean a screw on plug to remove the antenna base altogether then I don't know.
Old Nov 7, 2013 | 11:23 AM
kyoo's Avatar
kyoo
yeah just a plug in. don't need AM, FM reception is good without the antenna, and I use a car cover regularly. No big deal though, I just screw the antenna off when i put the cover on lol
Old Nov 7, 2013 | 11:36 AM
vetsvette's Avatar
vetsvette
Moderator
That's why I installed the stubby. It fits the antennae pocket on my cover.
Old Nov 7, 2013 | 11:44 AM
kyoo's Avatar
kyoo
:( my cheapo cover doesn't have one. which cover did you go with? if oem, is it a soft material on the inside of the cover?
Old Nov 7, 2013 | 12:49 PM
DTH2CHRM's Avatar
DTH2CHRM
I have the Alta Super Shorty and have no problems with FM or AM.
Old Nov 7, 2013 | 01:27 PM
vetsvette's Avatar
vetsvette
Moderator
This is the one I have. I bought from a member on the forum. So far seems to be a good quality cover and it has a small pocket that my Cravenspeed stubby works perfectly with. It's a tight fit so you don't have to worry about wind. Although it's listed as indoor and outdoor, I use it primarily in my storage building to protect it from dust, birds, etc.
Amazon.com: MINI Cooper Genuine Factory OEM 82110035883 Outdoor Car Cover 2007 - 2012 (Will not fit Clubman or Countryman): Automotive Amazon.com: MINI Cooper Genuine Factory OEM 82110035883 Outdoor Car Cover 2007 - 2012 (Will not fit Clubman or Countryman): Automotive
Aug 24, 2015 02:09 PM
bugeye1031
Aug 15, 2015 08:14 AM
Aug 7, 2015 05:56 AM
