R56 Loss of Peak Boost Pressure, Turbo Glowing
Hey everyone,
The issue I am having with my 2007 R56 MCS is that the peak turbo pressure (psi) is not as high as it normally goes. This started to happen after I had the cylinder head cover replaced due to the breather system leaking oil all over the place. Since this install (done by a Mini Dealership), the maximum turbo pressure on boost is around 13.3 psi and hovering around 12.0 psi after that peak during full boost. Before this problem started, it would peak around 15.1 psi and hover around 13.9 psi or 14.0 psi. I am wondering what would cause this peak boost to be an issue? I definitely notice a decrease in the pick up, the turbo spool speed, and the overall quickness. The issue does not go away with an alta accessport tune, where the peak used to be 19.2 psi on my car it is now around 17.5 psi. Any help here would be appreciated, as I have no clue what could be causing this.
The second issue is since I have been running the car hot trying to get some psi numbers on the boost, every time I bring the car home, I notice that the turbo itself (under the heat shield) is glowing red. Now this alarms me because I don't believe I need an oil change (just got one earlier this year) and I am worried it might not be getting enough oil. Is this normal, has anyone else seen their turbo glow after a hot run?
Thank you guys for all your help, this is my first forum post but I have enjoyed all the help and assistance I have received from other posts. Happy motoring!
Make sure there aren't any hoses pinched off from when they did the valve cover install. Ideally just take it back to the dealer and tell them they broke it they fix it. Where does your boost gauge tap into the intake piping? You could have a leak between the turbo and intake manifold causing you to not reach peak boost. It also could cause the car to run really lean which would raise EGTs and cause your turbo/exhaust to get really really hot. However, I would think you would get a CEL or something from a lean cylinder.
Your turbo glowing red doesn't have to do with the oil or coolant plumbing. The coolant only cools the turbo shaft housing. The oil lubricates and cools the bearings. If you're running at 19psi continuously, it is normal under EXTREME load cycles for the turbine side of a turbo to get extremely hot and to the point where there is a very very very slight glow. It should not be bright cherry red at these levels. That could indicate another in-cylinder problem. I'd probe at what your EGTs are and talk to Alta, but they may or may not be able to help you.
I was thinking the same. The cat being blocked would increase backpressure and a lot of heat. You can have the cat tested for back pressure at a shop. There is a gauge that screws into the O2 sensor hole.
Thank you guys for your help. I checked, and right now I am not throwing any codes. However, I am planning on changing the down pipe in the near future, that could help out. I am also taking it back to Mini and telling them that it was their install that caused the problem so they should at least diagnose it, and fix it. I'll be sure to check the O2 sensors and codes again before I take it in, and I'll be sure look at all the lines/hoses around the area they installed the cylinder head cover. Thank you!
Thank you for all your help guys. I have decided to not drive it until I take it into the Mini Dealership next week because these issues only started after the work they did on the car. I agree that with the turbo running so hot, it could really damage the whole system. Thank you for your help and I'll let you know what happens with the fix!
Colt45Magnus
Aug 27, 2024 05:03 AM
Sep 3, 2015 10:29 AM
doug5g
Sep 2, 2015 04:53 PM
