R56 Brake Issue...need help.
Old Jun 29, 2013 | 08:29 PM
DRoc7822's Avatar
DRoc7822
So i finally did the brakes last weekend (Front and Rear...rotors and pads) and somehow along the way... I mistook the abs sensor for the brake wear sensor. I took the ABS sensor off the car... realized what I had done and then reinstalled the sensor. Now I have the ABS/Traction symbols on in the car. I tried taking the sensor out again to clean it off and reinstalled it again. Yet still have the light. Have I done something and need a new sensor... or whats going on?
Old Jun 29, 2013 | 08:48 PM
chrunck's Avatar
chrunck
Have you driven it? You might just need to drive a few miles.
Old Jun 29, 2013 | 10:38 PM
DRoc7822's Avatar
DRoc7822
Yeah I have...at least 100 miles since I took it off. I did just clean it though last night and drove it today for maybe 15 miles or so. I was kinda hoping the light would go off on itself to but so far nothing.
Old Jul 1, 2013 | 08:41 AM
NJ Mini's Avatar
NJ Mini
Have you tried disconnecting the battery for 15 minutes yet? Give it a shot. Cheaper than going to the dealer.
Old Jul 1, 2013 | 09:07 AM
Did the abs sensor head crack or damage? When you removed the abs sensor from the steering knuckle of "carrier" did you crack it. They tend to stick and can rust around the sensor then you go to pull it out and it snaps a little.
ABS sensor head
#2 is the knuckle "carrier where it insert above the wheel bearing.
#8 is the sensor.
#8 ABS Speed Sensor - Front Part number 34526851500
http://www.ecstuning.com/Search/SiteSearch/34526851500/
Also check the connection at the blue side , there are little metal prongs inside the housing , if they don't insert into the cable plug harness just right they can bend a little and then not catch the square holes and make contact, thus the ABS light.
Here is the rear , the same idea, I did not know if you took one of rears off also.
# 21 below ABS Speed Sensor - Rear 34526851501
http://www.ecstuning.com/Search/SiteSearch/34526851501/
#21 ABS rear sensor #4 The rear trailing arm.
Old Jul 1, 2013 | 04:52 PM
DRoc7822's Avatar
DRoc7822
Thanks for the response!! I didnt really notice any kind of damage or cracking on the housing or anything. But maybe I over looked it. Ill check the blue part again to just to make sure. I didnt do the same to the rear..so if I do need one it'll be just for the front. Kind of a stupid mistake to! Again thanks for the advice and help!
Old Jul 1, 2013 | 06:26 PM
DRoc7822's Avatar
DRoc7822
I just went out and messed with the blue plug a little more and I guess I didnt have it plugged in all the way. All is well now. No ABS/Traction symbols when I turned the car on! Woot Woot!!! Thank you again for the help! Its much appreciated!
Old Jul 2, 2013 | 07:46 AM
RobertJ's Avatar
RobertJ
Thanks for the follow-up!
Old Jul 2, 2013 | 08:05 AM
Great,
Glad I could help.
Had to be one or the other.
embiggenedmini
Oct 15, 2015 12:36 PM
Gremothra
Sep 9, 2015 08:42 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
