R56 Rear top strut holes stripped
Old Jun 30, 2013 | 05:56 PM
NintenTom's Avatar
NintenTom
Does anyone have any solutions to a not so common problem? The top two holes that hold the rear strut on my driver's side are stripped. Dealership quoted me 5-6k to fix it via body shop. They suggested taking out the current section via weld and welding back in a new part with new holes.
I will probably bring it to a independent body shop as well to see what they think. Just wanted to see if anyone has had this similar problem and what they ended up doing to fix it.
Old Jul 1, 2013 | 05:22 AM
richardsperry's Avatar
richardsperry
I'd be asking how it got stripped in the first place? If you did it, shame on you. If they did it, it's their problem...
Old Jul 1, 2013 | 05:31 AM
countryboyshane's Avatar
countryboyshane
Ha ha ha! What a ripoff!
Helicoil the two holes. 30 dollars
Old Jul 1, 2013 | 06:53 AM
simplyj's Avatar
simplyj
2nd that! Shame on that dealer
Old Jul 1, 2013 | 10:59 AM
NintenTom's Avatar
NintenTom
I was thinking that too but not sure if there's enough room for a drill to fit in there.
Old Jul 1, 2013 | 12:14 PM
countryboyshane
They make "right-angle" drills, both pneumatic and electric. The threads are then tapped by hand. It can be done.
Old Jul 1, 2013 | 06:04 PM
k_h_d's Avatar
k_h_d
Would it also be possible to just retap to a larger bolt size?
Old Jul 1, 2013 | 07:21 PM
Summons's Avatar
Summons
Can't the threaded holes be replaced with washers and nuts? The washer to spread the load onto the mount area, and nuts to clamp it all together?
E
Old Jul 2, 2013 | 08:18 AM
Helix13mini's Avatar
Helix13mini
E
No I believe it's a boxed in section. Actually, to save those quoted thousands, you could cut away the boxed section long enough to weld in bolts on the back side to thread into, and then weld new sheet metal.
The Helicoil idea might work as well, depending on how much meat there is on those threaded bores. Remember that these bolts are not loaded unless the car is off the ground, so unless you are jumping busses Evil Kneive-style, you should be okay with Helicoil.
Old Jul 2, 2013 | 12:54 PM
NintenTom's Avatar
NintenTom
You're right. I stripped out the interior and it's a double panel.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Dec 23, 2015 10:36 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
