R56 One headlamp randomly does not come on.
Old Jun 24, 2013 | 03:38 PM
MIRussianNI's Avatar
MIRussianNI
My passager side bulb does not come on from time to time. When it does come on it comes on with a bright flash, while the other one just turns on normally. I have the OEM HIDs. Im thinking it's not the bulb, so its probably the igniter or the ballast. In which case does it make sense to just switch over to aftermarket HIDs, rather then paying for OEM parts? Thanks
It is an 07 MCS
Old Jun 24, 2013 | 05:23 PM
InjectedGT's Avatar
InjectedGT
You might be able to find factory replacement parts cheaper than at the dealer. In that case, I would just replace the bad balast because there is really no reason to go through fitting aftermarket equipment all around when you can just replace the one bad part.
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
chowpott
Oct 19, 2015 08:37 AM
schr5530
Oct 5, 2015 08:28 AM
Oct 1, 2015 12:13 PM
