R56 N18 Oil consumption
Old Jun 19, 2013 | 05:23 PM
gerry2153's Avatar
gerry2153
N18 Oil consumption
I had heard that the older MINI's had issues with oil consumption. So I was hopeful that they had gotten a little better with the N18 motor. I had been changing the oil every 4K and never noticed it used very much, but I missed the mark on the last 8K period so I decided to just wait till the counter expired and just let the dealer do it.
So it was about 8200 miles since the last change and it was dead center between the two marks on the (crappy) dipstick....
Seems pretty good to me. . . I guess I broke her in pretty good... LOL
Old Jun 19, 2013 | 05:56 PM
M'Cooper's Avatar
M'Cooper
Mines been ok, Its used very little. I just turned 8500 miles and had a 3500 oil change and am getting my first Mini free one this Saturday.
Old Jun 19, 2013 | 07:54 PM
afadeev's Avatar
afadeev
Same here: N14 '08 MCS, 50K miles, no extra oil needed between 6K oil changes.
FWIW, MINI does not claims any expected oil consumption levels, but BMW has always advertised "1 quart per 1K miles is within norm" position. All of my previous bimmers used either no oil, or at most 1 quart per 5K.
YMMV,
a
Old Jun 19, 2013 | 08:41 PM
Systemlord's Avatar
Systemlord
You think you have it bad, I need to add 1/2 quart of oil every 800--1000 miles (N14)! Darn that PCV system!
Old Jun 20, 2013 | 02:50 AM
M'Cooper's Avatar
M'Cooper
Oops I thought this was about N18 oil consumption. The little bit I wouldn't say was bad. My BMW would use a quart every 1000 miles as well lol.
Old Jun 24, 2013 | 09:54 AM
cameo1957's Avatar
cameo1957
oil comsumption
on the 2007-2010 check the vacuum pump {on the vacuum hose side} for oil- if it shows any sign of oil- replace the vacuum pump immediately.
this has been known to cause catostraphic engine failure{s} by sucking all the oil out and burning it - then the pump seizes - locks up the cam
- you may not see any external leak - remove the vacuum hose {gingerly} if you see oil you have a problem.
Old Jun 24, 2013 | 12:00 PM
greasypeanut's Avatar
greasypeanut
38k miles on mine, no appreciable oil consumption. from reading the forums i was paranoid and carried a bottle of oil in my car for the first months of having my car. thankfully it seems mini fixed/improved the engine
Old Jun 24, 2013 | 12:22 PM
TheBigNewt's Avatar
TheBigNewt
I went years without needing oil between changes (about every 8k miles). But this year I needed total 3 quarts between changes (about once a year I don't drive much). Go figure. I've got 60k miles on my 2007 now.
Old Jun 24, 2013 | 01:56 PM
NCapurata's Avatar
NCapurata
I've had my 2009 MCS since 2/2013. The dealer records showed that the "Complementary Oil Change" occurred at 28,XXX miles. I bought the car at ~30,000 miles, and did an oil change then. Between 31,000 to 35,000 I did not see any consumption of oil. My driving was all 30-45 minute drives on highway (approximately 50 miles / day).
Two weeks ago I took the car in for an oil change at the dealership @ 35,000. Since then, I added 1,100 miles. 1,000 of which came from a trip I took this weekend. All highway miles at average speed of 70-75 MPH.
I checked the oil today, and it seems to be about 1/4 (or a bit more) down from the top marker.
Quite unusual in comparison to my first 5,000 miles.
Can anyone tell me where the vacuum pump /hose that is referenced in the post above is located? I want to see if there is a problem.
I'm thinking of going back to the dealership and inquiring as to the sudden oil "gone missing".
Old Dec 18, 2020 | 12:27 PM
shanti's Avatar
shanti
Resurrecting as since I got my 2012 MCS N18 (41k miles on the clock), made exactly 1000 miles after purchase, just checked the oil level and the car hasn't used any. I know that the dipstick design is extremely stupid, but is it possible that the "1-quart-every-1000-miles" does not apply here?
I drive around like a crazy person with a quart of oil in the trunk just in case it needs a top up - or does it apply only to N14? Thanks!
Old Dec 18, 2020 | 12:42 PM
Capt_bj's Avatar
Capt_bj
We have a 15 Roadster with the N-18 (bought new)
I have NEVER had to add oil between changes .... and I do changes BY THE COMPUTER INTERVAL . . . approaching 50,000 miles
and yes, I check it regularly ....
Old Dec 18, 2020 | 04:49 PM
Gubi's Avatar
Gubi
It depends on the N18. My 2012 CS burns a quart every 3500-5000 miles.
From an automotive oil consumption standpoint that's pretty minimal. But even just doing 5K oil changes I'd be down over a quart if I didn't top it off, and a quart is a LOT in a car that only holds about ~4 qts total. So it's pretty important to check oil levels regularly in these cars.
Old Dec 19, 2020 | 02:58 AM
Jason Cornelius's Avatar
Jason Cornelius
I really honestly think the oil you use has something to do with this as well. I have been using Castrol edge 5w-40 for pretty much the whole year I have owned the car, and yes N14 here. Depending on how it was driven I would burn 1qt 1000 to 1500. I did a liqui moly engine flush and swapped in their 5w-40 and motor oil saver. 2200 miles later and I’m down 1.25 qts, so far so good with the liqui moly.
Old May 6, 2021 | 07:42 AM
shanti's Avatar
shanti
Resurecting this again for a quick sanity check - have done 2800 miles since my last oil change (the chain tensioner was replaced as well).
The oil level is slightly above the half mark on the dipstick. Is this fine or excessive? I drive the car mostly on open roads and highways, almost no city driving. Do like to stretch it's legs every once and a while
I plan to change oil every 5.5k miles.
Old May 6, 2021 | 08:13 AM
Jason Cornelius
If I’m not mistaken half way down on dipstick is 1/2 of qt, which is good over 2800 miles. I’m pretty sure 1qt over 1500 miles is an acceptable mini standard.
Old May 7, 2021 | 12:05 PM
crazy4trains's Avatar
crazy4trains
So, what is the agreed upon cause for most cases of oil consumption on the N18? My M54 (2002 BMW 530i) has a known issue with low tension piston rings that get carbon fouled after time. I've come up with a fuel treatment regimen that has significantly slowed that consumption and am wondering if most cases of N18 oil consumption are also piston ring related.
Old May 10, 2021 | 10:54 AM
shanti's Avatar
shanti
Update - I've driven the car for a bit longer (the last time I checked the oil it was a trip of 10-15 miles) and it appears that the oil level is just above full now. What the heck?
One thing though, I did park it nose first, the last time it was reverse. But it couldn't possibly be the change in elevation as the incline is like 1%. Or could be?
Old May 10, 2021 | 09:07 PM
mountainhorse's Avatar
mountainhorse
Oil weight and volatility has a lot to do with it... If you live in a warm environment... go with a 10W-30 oil and the NOACK numbers (an indicator of evaporative loss) will drop....
OR... Stick with a 5W-30 with great NOACK numbers like Redline or Amsoil...
It will make a difference in oil consumption...
0W oils like 0W-30 or 0W-20... Will get you a lot of evaporative loss and 'oil consumption'...I'd only use them in Super-Arctic temps.
I think oil choice with good spec is important...
Old May 13, 2021 | 11:37 AM
shanti's Avatar
shanti
I'm using 5W-30 BMW branded (I presume it's Castrol), checked again after 220 miles of highway driving (85/90 MPH mostly) and it is above the half mark.
So, half a quart after 3100 miles?
Old Jun 11, 2021 | 07:48 PM
mountainhorse
Again...the evaporative loss is a pretty big deal on ANY GDI engine... and most engines in general...
Don't be tempted to go with any 0W oil unless you live in the Arctic... or run sub -20˚-F all the time.
Low NOACK numbers are a good indication of that volatility or propensity for evaporative loss of the oil... The evaporative loss WILL be sucked back into the engine... coating the intake valves (that are not 'washed' with gas from port injection)... and into the combustion chambers.
Also, this evaporative loss will change the lubricity and chemical properties as the oil 'thickens' from loosing this component of the oil that 'boils' off first. (think of an overcooked soup )
NOACK numbers in the sub 7% will give you some great results if the properties of the oil are good to start with.... Redline, Amsoil and some others come to mind.
A $50 tag on oil for your oil change should be considered a good investment IMO.... less deposits, better long term stability of the oil as a lubricant, and a cleaner engine....
Just something to "chew on".
Old Jun 12, 2021 | 01:12 AM
shanti's Avatar
shanti
On that note, when should one add oil? When the level on the dipstick falls just under the 1L mark?
Old Jun 21, 2021 | 10:24 AM
crazy4trains
There is no best time to add oil. Add it when you know it is low.
Old Jul 28, 2021 | 01:04 PM
troyegly's Avatar
troyegly
Mobil 1 0w/40 is their European blend formula. So do not use it for Mini's?
Old Jul 29, 2021 | 06:14 AM
crazy4trains
Explain your logic please.
Old Sep 9, 2021 | 05:07 AM
Einric's Avatar
Einric
The owners manual says that Mobile 1 0w40 is tested and certified for the N18 engine.
It's easier to get ahold of.
Pennzoil Platinum 5w30 was also on the list in the manual.
Project Farm on Youtube tested this oil to flow extremely well at cold temperatures and cook off even less than the Mobile 1.
I've always used Mobile 1 Full Synthetic in all of my vehicles without any issues whatsoever.
BUT, maybe I'll give the PenzPlat a try with my Countryman S....
