R56 Maintenance Contract about to expire...what to fix?
Old May 9, 2013 | 10:17 AM
Dr Strangelove's Avatar
Dr Strangelove
Coming up on 3yrs of the maintenance warranty. Wondering what I should make sure they do for me before it actually expires. The car is a Cooper S with 25K miles on it.
Old May 9, 2013 | 11:32 AM
Chimera's Avatar
Chimera
They will only do what the computer tells them to, along with smaller stuff like wiper blades.
Old May 9, 2013 | 11:33 AM
Dr Strangelove
I'd like to have the brakes replaced
Old May 9, 2013 | 11:34 AM
mbwicz's Avatar
mbwicz
I would ask if they can inspect for carbon buildup and clean if required. Even though it is not scheduled maintenance, maybe they can cut you a deal if you need to have it cleaned. See if you need new wipers as well, those are covered (at least they were in my extended maintenance package), but the customer needs to complain. Other than that, the car tells them what to do (brakes, brake fluid, oil changes).
Mike
Old May 9, 2013 | 11:35 AM
mbwicz's Avatar
mbwicz
the brakes have sensors that tell the car when the pads are worn. Unless there is a vibration or noise, they probably won't replace the brakes.
Mike
Old May 9, 2013 | 11:36 AM
Chimera's Avatar
Chimera
Is the light on saying they need replacing (or at least close, check the service menu to see how many miles till it's due)? If not, they won't replace them.
Old May 9, 2013 | 11:38 AM
Dr Strangelove
Thank you, need to check that one.
Chimera's Avatar
Chimera
Good call on the carbon cleaning, but that's covered until the end of warranty not just the 3/36 maintenance.
Old May 9, 2013 | 11:39 AM
Dr Strangelove
Mike
Thank you. I have noticed the car has been sputtering now as the weather has gotten warmer especially when its not warmed up yet. Kind of worries me as this car seems like a ticking timebomb when it comes to maintenance issues.
Old May 9, 2013 | 11:53 AM
NJ Mini's Avatar
NJ Mini
As much as I'd tell you to get the brakes done, they won't do it before the sensor trips or the service-info shows less than 4,000 miles until the brakes are due.
They replaced my fronts just before the program expired and it was a joke. I only received new pads. Rotors were not resurfaced or even cleaned. Now 3,000 miles later I need new rotors, so I'll probably just replace the pads as well.
Old May 9, 2013 | 11:58 AM
Dr Strangelove
Man thats bunk.
molala
Oct 2, 2015 01:53 PM
ronn
Sep 9, 2015 07:12 PM
Sep 4, 2015 03:56 PM
Sep 3, 2015 12:24 PM
