R56 bbs style 5 wheel fitment
Old Mar 25, 2013 | 02:48 PM
Riccobonoj's Avatar
Riccobonoj
Okay i do not have my mini yet but will be getting it shortly and i want to know how aggressive 17x8 et20 all around would be with stock suspension or just mild drop with springs. As said in title i am talking about bbs style 5 rc090 wheels
Old Mar 25, 2013 | 03:19 PM
HKSpeed's Avatar
HKSpeed
are you going to have the wheels filled and redrilled from 5x120 to 4x100? or use adapters?
if you use adapter, you'll probably need 20-25mm. that'll bring your offset to 0 or +5.
by the way, you should ask this question on stanceworks or wrongfitmentcrew. the folks around here are more function>form.
Old Mar 25, 2013 | 04:08 PM
Riccobonoj's Avatar
Riccobonoj
Yea i would redrill them i know adapters is way to much poke. It is more function really i am not slamming it i just wanted to know if the poke would be rediculous and if i would clear the struts and shocks
Old Mar 25, 2013 | 05:20 PM
Creeve's Avatar
Creeve
Answer is here: https://www.northamericanmotoring.co...d-mini-44.html
Old Mar 25, 2013 | 05:59 PM
Riccobonoj's Avatar
Riccobonoj
I don't know if i am going crazy but in that thread i do not see anything about the size of the wheel and fitment just the lowered part
Old Mar 25, 2013 | 06:02 PM
Creeve's Avatar
Creeve
The red car on the page I linked has style 5 bbs 17x8 et20 redrilled to 4x100, which is also stated on the same page.
Old Mar 25, 2013 | 06:10 PM
Riccobonoj's Avatar
Riccobonoj
what is the name of the forum member ill search his posts on the thread because i cannot find it sorry
Old Mar 25, 2013 | 06:16 PM
Creeve's Avatar
Creeve
Are you saying the link doesn't work?
The username is redandblackminis
Old Mar 25, 2013 | 06:22 PM
Riccobonoj's Avatar
Riccobonoj
Oh okay i see him now. in your opinion with those wheels at stock height or just a mild drop would be to much poke since the car will not be slammed or have negative camber
Old Mar 25, 2013 | 07:24 PM
Jaydavid's Avatar
Jaydavid
Way to much poke and if u drop it ur gonna rub bad. My wheels are 17x8 et 35 at stock hight and the back arches are pretty much rubbed away now haha.
Old Mar 25, 2013 | 08:22 PM
Riccobonoj's Avatar
Riccobonoj
I can probably get the offset shaved to about et 25 which i dont think would be to bad. What are you rubbing on the inner part or the fender flares on the out side
Old Mar 25, 2013 | 08:35 PM
Jaydavid's Avatar
Jaydavid
its on the inner part but its rubbed enough to make the plastic come lose. I do have 225 tires on it tho which is part of the problem. the 35 offset is perfectly flush with the fenders so 25 will still poke out so if you do go with that your going to want 205 tires with a stretch. If you lower it your going to have to go 205 otherwise its gonna rub them away in a few days. Or you can always have a shop roll your fenders
Old Mar 25, 2013 | 08:39 PM
Riccobonoj's Avatar
Riccobonoj
Do youthink if i get a 205 stretch it should be okwith the rubbing after it runs for like a couple days? ...only the rear?
Old Mar 25, 2013 | 08:40 PM
Riccobonoj's Avatar
Riccobonoj
You have any pictures of you poke or car
Old Mar 25, 2013 | 08:51 PM
Jaydavid's Avatar
Jaydavid
Depends on how far the 25 offset sticks out i don't know how much more extreme another 10 mm would be. A little rub on the inside is ok but the outside is a problem. Yes only the rear rubs with my setup. If you plan on ever lowering it id advise don't go over a 30 or 35 offset because your going to have alot of problems. i kno a 205/40 tire is a little shorter than the 205/45 tire that might work but i really cant say.
Old Mar 26, 2013 | 05:34 AM
Creeve's Avatar
Creeve
A mild drop, some 205/45/17s and some camber front and rear. I think you can pull it off. You can get fixed camber plates for the front pretty cheap.
Kimolaoha
Dec 5, 2020 09:32 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
Aug 7, 2015 05:56 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
