R56 What do I need to know about changing my wheels?
Old Jan 15, 2013 | 07:09 AM
cDecker32's Avatar
cDecker32
So I bought a set of blizzaks from tirerack with all the sensors and stuff.
Is there anything specific I need to know about swapping wheels? Like how much torque should I put on the bolts, and how do I reset the sensors?
Old Jan 15, 2013 | 07:14 AM
Helix13mini's Avatar
Helix13mini
We do 104 ft/lbs with anti-sieze on the threads and hub.
Old Jan 15, 2013 | 07:42 AM
Porthos's Avatar
Porthos
That it will look awesome when you swap them out.
Old Jan 15, 2013 | 07:50 AM
Braminator's Avatar
Braminator
Use a jack.
Old Jan 15, 2013 | 07:57 AM
Jay H's Avatar
Jay H
I just did the exact same thing (sensors and Blizzaks from The Tire Rack). I insured the new setup was at the correct pressures and bolted the new rims and tires up. I had no issues with the TPMS settings and received no warning lights after doing the swap.
Old Jan 15, 2013 | 08:44 AM
cDecker32's Avatar
cDecker32
Ok, so theres nothing I need to reset or anything with the computer?
Old Jan 15, 2013 | 08:49 AM
Jay H's Avatar
Jay H
My summer rims and tires were set to 33 psi and the winter rims and tires are set to 35 psi. I didn't touch anything on the TPMS settings on the on board computer and have received zero warnings.
Old Jan 15, 2013 | 09:35 AM
The M People's Avatar
The M People
I switched my summer rims and tires out about a month ago with a set of winter rims and tires plus the TPMS. I did not touch the computer and no warning so far.
Make sure you check the torque again after say driving 50 miles.
Old Jan 16, 2013 | 02:39 PM
C4RACER's Avatar
C4RACER
on a R56 you will need to reset the computer. It isn't too difficult - there is a how-to around here somewhere and it may also be in the manual.
Old Jan 17, 2013 | 04:27 AM
yetti96's Avatar
yetti96
If you do get an error, you the BC (stalk end button) and go to the TPMS screen and select reset and drive for a mile or two.
Old Jan 17, 2013 | 08:03 AM
Jay H's Avatar
Jay H
I did some more reading on the TPMS system. After changing out the tires, you need to reset the TPMS system so that it recognizes the new air pressure values in the new rim and tire setup (essentially establishing a new baseline pressure for each tire). If you don't do this, the TPMS system may not function correctly in the event of a flat or low pressure situation. It's easy to reset. Check your owners manual for the procedure.
Old Jan 18, 2013 | 11:55 AM
NJ Mini's Avatar
NJ Mini
Other than resetting the TPMS light, you'll need to either buy or borrow a torque wrench to properly tighten the wheel bolts.
sevin
May 2, 2026 06:11 AM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
skippermini
Aug 12, 2015 10:05 PM
