R56 iPod worked, then did not work - any ideas?
Old Nov 30, 2012 | 07:15 AM
biserker1's Avatar
biserker1
Hey,
I have been driving around for two months with my iPod hooked into the mini iPod cabled that plugs in under the dash. It's the Y cable that you purchase from mini.
Synced my iPod last night and this morning it charges through the cable but the car does not recognize it. When you select USB it says "Empty."
Any ideas?
Old Nov 30, 2012 | 07:25 AM
jhull413's Avatar
jhull413
Try doing a reset on the ipod and then re-syncing it. Only a guess, this has never happend with mine. I listen to audio books a lot and most times the book will continue where I left off the last time and occasionally it will start over so I suspect the relationship between ipods and the MINI is less than perfect.
Old Nov 30, 2012 | 07:51 AM
biserker1's Avatar
biserker1
Same thing with me - it worked great! Now - does not work. will try the reset.
Old Nov 30, 2012 | 08:51 AM
biserker1's Avatar
biserker1
Did the reset - same problem. Charges and plays through the aux but not through the USB!!!!
Old Nov 30, 2012 | 09:08 AM
pheatton's Avatar
pheatton
Sounds like what happened on my 2011, the Y cable worked for a few times then never worked again. Dealer replaced the cable still nothing. I complained about it every time the car was in the shop and they couldn't determine the issue....
Old Nov 30, 2012 | 09:36 AM
biserker1's Avatar
biserker1
I looked into the input in the car. I see three pins and am wondering if there should be
4 pins. Maybe one pin was bent? I am going to "explore" now....
Old Nov 30, 2012 | 11:50 AM
biserker1's Avatar
biserker1
Looks like there are four pins and the second one is broken - a trip the dealer will be underway.
Old Dec 28, 2012 | 09:23 AM
biserker1's Avatar
biserker1
Update-the iPod port was broken. Two of the four pins were damaged. Dealer replaced the port.
Herleman
Aug 16, 2015 06:41 PM
minipopkart
Aug 13, 2015 05:22 AM
Jgj1988
Aug 12, 2015 10:11 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
