R56 How To Do a Burnout ?
Old Nov 17, 2011 | 03:37 PM
FUBSZ's Avatar
FUBSZ
hey guys i was just wondering how can i do a burnout on a mini ? just lift up the E-brake and gas it ! but its not working :( i got carbotech performance brakes and it just doesnt seem to hold .
Old Nov 17, 2011 | 04:44 PM
walk0080's Avatar
walk0080
I don't think it's so much an issue with the brakes as it is with the handbrake not being designed for that kind of use. Blocks of wood in front of the rear tires might work. Or take some tow rope and the tow hook hehe
Old Nov 17, 2011 | 04:50 PM
the matey's Avatar
the matey
Turn traction control off, rev it up to 5000 then drop the clutch
Old Nov 17, 2011 | 04:53 PM
gds194's Avatar
gds194
you do have a standard? and are you a S car?
Old Nov 17, 2011 | 07:13 PM
CLAG's Avatar
CLAG
MINIs are great cars, but they don't have enough HP for a proper burnout (and the power goes to the wrong end).
Old Nov 17, 2011 | 07:14 PM
walk0080's Avatar
walk0080
Doing a burnout over here will give you an immediate license suspension and car impound (+ up to $10000 fine I think)... it is officially considered street racing.
Old Nov 17, 2011 | 07:44 PM
dannyhavok's Avatar
dannyhavok
Before I looked at your location I thought, "must be a fellow Canadian!"
Looking at a highway cop the wrong way is street racing, more or less. They have made the definitions so vague (in BC anyway.) that just speeding can be defined as racing, even if there are no other cars.
Old Nov 17, 2011 | 07:45 PM
walk0080's Avatar
walk0080
Yes exactly. Doing 50km/hr over the limit by yourself is also street racing in Ontario. Yes that is fast, but street racing... hmmm.
Old Nov 18, 2011 | 12:46 AM
FUBSZ's Avatar
FUBSZ
lol , so its not possible to do it ? i have an S automatic tranny :(
Old Nov 18, 2011 | 01:09 AM
MINImal lag's Avatar
MINImal lag
Uh....... Why ?
Old Nov 18, 2011 | 01:36 AM
Achilles honor's Avatar
Achilles honor
Why Would you want to do a burnout in your car.. If you give me a good excuse I will tell you how to do a burnout.... You better be in a save a baby burnout contest cause anything less is just stupid
Old Nov 18, 2011 | 05:11 AM
Porthos's Avatar
Porthos
Ok reallllyyyyy, you can't do a burn out in a MINI........you clearly are high.....clearly. Since you have an auto it might take some creativity to get it to work but traction control off, pull up on the hand brake, and start easing into the gas at some point it should start spinning you might drag the back tires though. Or the othe way which I don't really suggest but you can try is same up until the handbrake. At the same time as mashing on the gas you can pull the ebrake. Also try power braking and see if that works. Auto is going to hold you back stick shift is so much easier.
Old Nov 18, 2011 | 05:15 AM
ZippyNH's Avatar
ZippyNH
Buy really cheap, narrow tires...find a spot with a bit of sand on the blacktop...turn off traction control....
But as stated before...why?!
Old Nov 18, 2011 | 05:22 AM
SSSSSSSS's Avatar
SSSSSSSS
Coordinator :: M2C2
You can always bring it down to Oakboro, NC where they hold a town sponsored monthly burnout contest. You can fry your tires to your heart's content. They even keep water and fire extinguishers on hand for burning asphalt. Tires are less of a problem. :-)
And, yes, you can most certainly do burnouts in a MINI. Not as effective in an automatic, but certainly doable. DSC/ASC must be turned OFF. Sport button helps too.
Old Nov 18, 2011 | 05:24 AM
SSSSSSSS's Avatar
SSSSSSSS
Coordinator :: M2C2
As for the why of it, it's a fish thing.....just for the halibut.
Old Nov 18, 2011 | 05:35 AM
gds194's Avatar
gds194
Ohhh, an Automatic..... Soak the tires in water, maybe toss is a light oil, sit down, buckle in, fire up the S motor, place trans in neutral.... slowly start revving and once the numbers are where you want "POP" it into gear...
Ahh, nothing like a neutral drop! But only if you have a checkbook or credit card!
Old Nov 18, 2011 | 06:53 AM
NJ Mini's Avatar
NJ Mini
Why would you want to attempt this? It's terrible for the car and it's front wheel drive making things even more difficult. It's do-able, but why?
Old Nov 18, 2011 | 07:16 AM
christomapher's Avatar
christomapher
I think his question was how to do a burnout, not should he do a burnout. But I do agree with the general consensus here: burnouts are not really a good thing from a safety, legal and wear/tear standpoint. They sure can be fun, though!
Anyway, when I was driving my first car, a 1986 Buick Century Limited sedan, i-4 95hp 3-speed automatic column shift, I would try to do a burnout but it was hard because of front wheel drive and being automatic. On top of that, the car was very heavy and had this horrible jelly suspension. 0-60 mph in a Century took nearly a century. It had plush velour seats, wire wheel hubcaps and a luggage spoiler!
I found the only way to do a burnout (beside when being wet outside) was if I did a "paint burnout". I discovered I could spin my wheels on the parts of the streets that had paint markings on them (i.e. stopsigns, stoplights, school zones, emergency room drop off zones... kidding about the last two!).
So, just place your front wheels on the paint, keep traction control off and mash the throttle. If I was able to do it in my molasses-slow Century, then you could definitely do it in your SCooper.
Just BE CAREFUL and watch out for other cars and pedestrians... seriously. Maybe try to find a deserted parking lot. Good luck!
Old Nov 18, 2011 | 07:17 AM
drewstermalloy's Avatar
drewstermalloy
Who cares why? It's his car, he asked the question and just wants answers.
But anyways, when I had my base Cooper I used to do it all the time (but it was a 6 speed). I would rev up to 6k, drop the clutch, and leave 20-30 foot skid marks on the road. It's good fun, but it's not something I would ever do again, especially to the JCW I have now.
Old Nov 18, 2011 | 07:42 AM
cereal's Avatar
cereal
That's what test drives and loaner cars are for!
Old Nov 18, 2011 | 08:20 AM
drewstermalloy
Old Nov 18, 2011 | 08:32 AM
AXO's Avatar
AXO
These cars were not designed to do burn outs. But what ever floats your boat. Being That a new automatic transmission will cost approximately $7,000.00 to replace, it would not be the prudent thing to do.
But if you insist. I would not use your parking brake. I would still power brake by holding the brake pedal to the floor and nailing the throttle. These cars do not have a tremendous amount of torque, so depending on tire and road conditions, I don't think it could be done with an Automatic.
Please let us know how it works out.
AXO
Old Nov 18, 2011 | 09:03 AM
christomapher
One other way is doing a "neutral drop" but its HORRIBLE for the car. Really should only be done on a rental car.
Old Nov 18, 2011 | 09:47 AM
gixxerjasen's Avatar
gixxerjasen
Not to be confused with a Reverse drop. R to D while rolling backwards. This is NOT recommended. I won't go into how I know about this, but it will ruin your transmission. :D
Old Nov 18, 2011 | 10:25 AM
Achilles honor
Only time i do burnouts is when i get a nice loaner lol
