R56 Tire Pressure Monitor has a mind of its own?
Old Oct 12, 2011 | 04:10 PM
90210oxygenblue's Avatar
90210oxygenblue
Hello there, 2010 MC. I have a dealer appointment set mid November
Over the last 8 months my Tire pressure monitor which indicates low pressure has gone off 4 times.
First two times, all tires seemed fine, I reset.
3rd time front tire had a leak, fixed it, reset
Fourth time again went off, no issues, I reset.
Lastly this weekend, it happened again. All tires are good, I check pressure religiously.
I have never heard of TPM so sensitive before. Or is mine malfunctioning on a semi regular basis?
I wanted some advice before my dealership says "we can't replicate the issue"
Old Oct 12, 2011 | 04:19 PM
wandrur's Avatar
wandrur
Moderator
Don't reset it next time, then take it in. Only thing I can think of. You're keeping up to manual's pressure specifications, yes?
Old Oct 12, 2011 | 04:22 PM
90210oxygenblue
Yes I have it to manual pressure specs. It seems to do it randomly, but ONLY when the car sits overnight. It never does it, if I am driving around, stopping, and restarting after errands.
When it happened before last year, I took it in to dealer with my annual oil change and they just reset it and said "well it was probably reading wrong for some reason" with no further explanation.
Thanks for the input.
Old Oct 12, 2011 | 04:33 PM
wandrur's Avatar
wandrur
Moderator
Weird. It could just be wonky.
Old Oct 12, 2011 | 04:34 PM
90210oxygenblue
I hope "wonky" can be fixed?
Old Oct 12, 2011 | 04:44 PM
wandrur's Avatar
wandrur
Moderator
Well, if it is faulty sensor, that should easily be covered under your warranty. Of course, they'll have to determine that it's actually faulty, which sounds like it might be complicated.
But, yes, if it is indeed an incorrect error, it should get rectified by your dealer.
Old Oct 12, 2011 | 04:47 PM
90210oxygenblue
I imagine the sensor is faulty or is going completely bad. Problem is given it is doing it once in a while, hard to just determine it is faulty by dealer.
I imagine it will completely fail the day after my warranty is out :( given my luck.
Old Oct 13, 2011 | 07:14 AM
satterfield's Avatar
satterfield
This used to happen to me all the time but I dropped my car off and they just fixed it, I think it was just a computer error.
Old Oct 13, 2011 | 09:25 AM
90210oxygenblue
Glad to know, thanks!!
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
