R56 Front windshield washer spraying fender?
Old Oct 12, 2011 | 04:05 PM
90210oxygenblue's Avatar
90210oxygenblue
Hello there, 2010 MC. I have a dealer appointment set mid November, but wondering if I can sort this out myself.
I was driving it last weekend, and when I turn on the front windshield nozzle, I get sprays coming from driver side and hitting the driver window by the exterior mirror.
No fluid hits the windshield and nothing is coming out of the bonnet nozzle.
Any help will be appreciated.
Old Oct 12, 2011 | 04:19 PM
drewstermalloy's Avatar
drewstermalloy
If you open the hood you can follow the sprayer lines to see if something is disconnected or torn.
Old Oct 12, 2011 | 04:20 PM
90210oxygenblue
Yeah I did that first thing, however all looks ok. Then again I don't know what OEM "ok" should look like.
Old Oct 12, 2011 | 04:38 PM
drewstermalloy
Open the hood and look inside while a friend turns the sprayers on? At least you'll be able to tell exactly where it's coming from or at least narrow it down.
Old Oct 12, 2011 | 04:40 PM
90210oxygenblue
Ok, I will see if a neighbor can help me. Downsides of living alone.
Appreciate it. I will report back.
Old Oct 12, 2011 | 05:13 PM
Mini-RI's Avatar
Mini-RI
wear glasses while looking!!
Old Oct 13, 2011 | 09:23 AM
90210oxygenblue
Thanks RI!!
Old Oct 13, 2011 | 09:55 AM
pheatton's Avatar
pheatton
Here is a pic of what it should look like under the hood:
Old Oct 13, 2011 | 09:57 AM
90210oxygenblue
PHAETTON
Thank you so much for that!! I will compare tonight, and if I can't sort it out will take a pic to show you.
Old Oct 13, 2011 | 10:01 AM
pheatton's Avatar
pheatton
Not a problem. Let me know if you need one of the engine bay area also. I can take one when I go to lunch.
Old Oct 13, 2011 | 10:02 AM
90210oxygenblue
You are extremely helpful! Thanks. I have the other car today, so I will do it when I get home.
WIll post back in the morning
Old Oct 13, 2011 | 10:58 AM
quikmni's Avatar
quikmni
The spray nozzle might just need to be adjusted. You can usually stick a pin in the nozzle hole and move the nozzle to aim it better.
Old Oct 13, 2011 | 11:02 AM
90210oxygenblue
THe two nozzles on the hood are spraying 0 fluid.
WIll look tonight and report back.
Old Oct 14, 2011 | 08:41 AM
90210oxygenblue
UPDATE
Hi guys
I think I found the problem. There seems to be the part of the hose that lays over the area of the fender turn signal on the driver side. That hose connects to the one under the bonnet. Mine at the edge, seems to be cut/torn.
I circled in the picture where there is a missing connection/hose.
So I guess thus the windshield fluid all coming out by the fender.
There doesn't seem to be enough hose to re-attach, almost like a chunk is missing.
Question
Is it something that will be covered under warranty by dealer?
If not, can I buy it and how difficult will be the full install?
Appreciate the help.
Attached Thumbnails Front windshield washer spraying fender?-mini-medium-.jpg
Old Oct 14, 2011 | 09:34 AM
drewstermalloy
I don't see why the dealer wouldn't replace that, but then again they could say it's "your fault"
Old Oct 14, 2011 | 09:47 AM
90210oxygenblue
Ok. I have a scheduled maintenance in November, will see if they replace it, if not, what the charge will be.
I am still surprised how its cut/torn at all. I have used it maybe 2 times in the whole time I have owned the car.
W0TM8
Dec 19, 2019 07:50 AM
Aug 19, 2015 12:51 PM
FLYM1N1
Aug 15, 2015 11:20 AM
