R56 Foglights on without headlights?
Old Sep 27, 2011 | 12:25 PM
Mindspin311's Avatar
Mindspin311
I have come across a few pictures of cars with their foglights on, but not their headlights. How do I do this? Is it something that needs to be programmed?
Old Sep 27, 2011 | 12:53 PM
rkw's Avatar
rkw
Foglights will turn on while just the parking lights are on.
Old Sep 27, 2011 | 01:21 PM
6speedwtneed's Avatar
6speedwtneed
Yup. Turn lights one click to parking lights then turn your fog light switch on. And BAM. =]
Old Sep 27, 2011 | 01:30 PM
Mindspin311
Thanks!
Old Sep 28, 2011 | 01:09 PM
RJKimbell's Avatar
RJKimbell
Those aren't the actual Fog Lights, those are part of the Parking Light System, the actual Fog Lights are below the Parking Lights in the same lens assembly.
Old Sep 28, 2011 | 01:28 PM
Mindspin311
You sure...
Old Sep 28, 2011 | 02:48 PM
Capt_bj's Avatar
Capt_bj
I don't understand the comment
but it is so far out I can't form a good question!
Ahhhhh
you are reading this
incorrectly. He's not sayiing the fogs ARE on in this condition, but that they CAN be turned on if the parking lights are on . . . .
Old Sep 29, 2011 | 04:16 AM
///Matthew's Avatar
///Matthew
On a related note....
Is there a way to make the foglights come on everytime you turn on your headlights?
Seems I have to hit the toggle switch each time.
Old Sep 29, 2011 | 04:36 AM
yetti96's Avatar
yetti96
The idea behind this is that you are not driving in fog every time you are driving with headlights on. In some states it is illegal to run fogs w/o a real need.
Old Sep 29, 2011 | 05:17 AM
///Matthew's Avatar
///Matthew
Fascinating
Old Sep 29, 2011 | 07:07 AM
drewstermalloy's Avatar
drewstermalloy
Does anyone think the foglights actually make a difference besides looking cool? I even have white bulbs in them and I barely notice when they're on.
Old Sep 29, 2011 | 07:16 AM
yetti96's Avatar
yetti96
Fascinating
I wouldn't go that far But on my last vehicle '04 F-150, you could leave the auto lights on and the **** pulled out for fogs all of the time. The euro automakers seem to be more in touch with the functionality and necessity side of things.
Sidenote:from a little reading on VW forums I noticed tons of guys and gals switch the headlight switch with the euro model to they can add rear fogs. Their switch has auto, off, parking lights, and headlight positions, then the switch has 2 spots to pull it out to, fogs, rear fogs. People do this for more control over the car's lighting choices and to recode the car to run fogs as DRL I think. Different car makers do it all differently.
Old Sep 29, 2011 | 07:25 AM
Number Six's Avatar
Number Six
At the risk of sounding like an idiot, can you explain?
I only see 3 light settings:
3. Off
2. Parking Light On (lower lights, separate housing from main headlights)
3. All lights On (Headlights and Parking lights)
(I haven't yet gotten into programming them).
So is there a separate "fog light" setting? And are the fog lights housed in the headlight assembly?
Old Sep 29, 2011 | 07:39 AM
///Matthew's Avatar
///Matthew
I don't think I've ever had a car where you couldn't set the fogs to come on all the time with the headlights, including two German cars.
Regardless of the meteorological conditions....I'm always in a fog.
Old Sep 29, 2011 | 07:44 AM
jcauseyfd's Avatar
jcauseyfd
In heavy fog, yes.
During the daytime as a form of DRL, possibly.
Old Sep 29, 2011 | 07:48 AM
jcauseyfd's Avatar
jcauseyfd
3. Off
If you have fog lights, there is a separate toggle switch for them in the center stack (with the windows, door lock toggles). As noted earlier, you have to switch your lights to at least the Parking Lights On position to enable the fog lights to come on when you hit the toggle switch.
The fog lights themselves are housed in the lower light assembly with the parking lights.
Old Sep 29, 2011 | 08:07 AM
Number Six's Avatar
Number Six
thanks.
Old Oct 1, 2011 | 07:17 PM
jmnegrin's Avatar
jmnegrin
And, answering a question that no one has asked yet:
Yes, in a former life, I found a need for driving with the fog lights on without the headlights on. It was at night, when it was snowing. The snowflakes were big, and reflected too much light back at me, even with the low beams. Yeah, I tried the high beams just for the heckuvit, and was quite sorry I did. The car I had at the time allowed the fog lights to be on with the parking lights, as mentioned above, and I found it worked very well, thank you.
Old Oct 1, 2011 | 08:29 PM
10Zero's Avatar
10Zero
Put in a set of Nokya Hyper Yellows, that'll make the difference. The OEMs are virtually ineffective as a fog light.
Old Oct 1, 2011 | 10:41 PM
ACEkraut11's Avatar
ACEkraut11
Plus the fogs do have an added benefit of acting as emergency headlights in the rare situation where you would lose both of your headlights. Not ideal, but better than nothing.
OutMotoring
Mar 3, 2017 06:29 AM
jeri534
Nov 6, 2015 01:40 PM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
