R56 turbo issue... help
Old Sep 10, 2011 | 07:11 AM
JChoneycutt44's Avatar
JChoneycutt44
turbo issue... help
ok so im new to this site and havent had a chance to read through all 101 pages of threads yet, so i appoligize if this has been covered but does anyone else have trouble keeping the hot side of the turbo inlet hose (hose between intake and turbo) attatched, mine keeps sliding off and i wanted to see if anyone else is having this problem before i pay out the *** to get my turbo fixed if, in fact, it is my turbo thats the problem. there seems to be a slight film of oil in the hose coupling but very little in the turbo itself. needless to say im a little confused.
thanks in advance
Old Sep 10, 2011 | 10:51 AM
bluefox280's Avatar
bluefox280
What year and mileage is on your car?
You're saying that boost pipe from the turbo compressor exit to the intercooler (hot-side discharge pipe) is sliding off the turbo housing?
Easy, simply remove the fitting, clean, and gently apply a very thin film of hair spray to the pipe and reattach.
Snug down with the clamp and that pipe should hold without issue.
- Erik
Old Sep 10, 2011 | 03:19 PM
JChoneycutt44
its an 08 MCS with 83,000. its the tube from the intake to the turbo not the turbo to the intercooler. the end that keeps sliding off is the end attached to the turbo but i may try the hairspray idea although i thought that may burn off before too long.
Old Sep 10, 2011 | 03:34 PM
mini4tide's Avatar
mini4tide
Yes. Oil from the turbo gets into the air intake pipe coming off the turbo. Even though its not under pressure, the angle it attaches as well as oil at the fitment site causes the pipe to slip off. Very poor design as the turbo flange should have a bead like the exhaust/hot side of the turbo has. I removed the crappy mini hose clamp, and replaced it with a T-bolt clamp. Pull the pipe and clean it out, then tighten the hell out of the clamp. The turbo is not the issue.
Old Sep 10, 2011 | 04:45 PM
desiletspo's Avatar
desiletspo
If you don't have hairspray, I use pepsi (or any high sugar drink) to hold my mountain bike handles in place. Maybe it's the oil from the oil vapor hose (the one connecting right before the turbo) that made the thing to slide out.
To clean oil, I love the brake cleaner from ''wurth'', this thing is very, very good, and it dries in seconds
Old Sep 11, 2011 | 08:58 AM
JChoneycutt44
thanks guys youve been a tremendous help. i will definatly try the hairspray thing and replacing the clamp. I wasnt aware of the oil vapor hose and how it can leak into the coupleing so you all have saved me a ton of money in figuring that out,
thanks again
Old Sep 11, 2011 | 09:15 AM
cschues80's Avatar
cschues80
I had that exact problem. If you over tighten it then it slides off. http://defendersofspeed.com/store/pr...?id_product=19
That is where I got my clamp 2 months ago. It's held ever since. There is a pic of where it connects. Hope that's what your talking about. Best part is...8$!!!!!!!!
Old Sep 11, 2011 | 09:45 AM
JChoneycutt44
also i was considering getting the ALTA hard inlet hose to replace the oem hose altogether. would that help or create a whole new set of problems?
Old Sep 11, 2011 | 10:06 AM
desiletspo's Avatar
desiletspo
I don't think it would worth the price. I would try cheaper solution before going to that. And i'm pretty sure you won't get any gain in performance, since it looks like it would be your only mod.
To answer your second question, no, it won't cause any problems
PéO
NYMADMINI
Dec 14, 2016 02:33 PM
GAT
Oct 4, 2015 07:27 PM
Oct 1, 2015 12:13 PM
M7Speed
Oct 1, 2015 07:05 AM
EVMini
Sep 28, 2015 10:20 AM
