R56 Best Spark Plug Choice for a 2008 MCS
I am having trouble selecting the correct Spark Plug for my 2008 MCS. As stated in my signature, the only performance mods are exhaust and a K&N drop in Filter. I tried doing a search but was unable to narrow it down. I am hoping some of the tuners could shed some light on a good plug.
Thanks AXO
Thanks AXO
Might want to check out this thread and then follow some of the links in the responses.
fwiw, as much as I liked the Brisk plugs I installed, I continued to have problems with them and have now gone back to the stock NGK plugs.
Slinger, is there a cooper NGK to run for those who don't want the OEM iridium or platinum?
And is there cooper plugs that are one-step colder for increased boost + combustion temps?
- Erik
- Erik
Www.sparkplugs.com
They show only the OEM iridium.
Why do you not want iridium? Just curious?
Copper has the higher electrical continunity value...
And they are typically cheaper in cost to produce...
And finding a step-colder plugs is needed when I run higher boost / combustion temps...
Plus, I'm willing to change them out much more often than the norm without a fuss.
- Erik
- Erik
I got a set of the NGK factory plugs (NGK (5992) ILZKBR7A-8G Laser Iridium) from Amazon.com of all places for $11.63 ea with free shipping....amazing what you can find from Amazon.com!
If you need a plug that will work in a little bit hotter running engine you can dress the stock NGK plugs. Just knock off the sharp corners on the side elctrode and the base of the plug. DO NOT hit the fine wire in the middle at all or the pad on the side electrode or you will damage the iridium and the plug will fail very quickly. I'd use a diamond file. The main place to focus is on the edge of the side electrode, it should be the hottest part of the plug, just be very careful. This isn't a bad thing to do regardless of the mods (even no mods), it shouldn't affect how long the plugs last or how well they stay clean, just gets rid of some hot spots in the combustion chamber.
silence2-38554
98
Sep 21, 2016 02:52 PM
R50/53 R53 Not Starting :(
maniacalmorgan
38
Sep 29, 2015 04:56 AM
