R56 Start up problem?
Old Aug 1, 2011 | 10:04 AM
CooperSGB's Avatar
CooperSGB
Start up problem?
I have a 2009 MINI Cooper S with just over 21,000 miles and an automatic/CVT transmission. I went to start it up just now and when I pushed the start button, it turned on, then the revs dipped below 1,000 RPM and the car stuttered for a second (almost as if you were about to stall a manual car) then jumped back up to normal RPMs. Is there something wrong?
Thanks in advance,
-G.B.
Old Aug 2, 2011 | 07:12 AM
miniemee's Avatar
miniemee
This could be carbon build up in the intake manifold. If so, needs to be cleaned out at the dealer with a cost of about 600.00 that is usually not covered under warranty or servicing.
Old Aug 2, 2011 | 07:48 AM
dannyhavok's Avatar
dannyhavok
The MCS does not have the CVT transmission, just an FYI. It was only present in the 2002-2006 Non-S Cooper. I believe all the MCS have the Aisin auto trans.
Old Aug 2, 2011 | 10:06 AM
Robin Casady's Avatar
Robin Casady
Not sure whether this is carbon, or something else. It could be a variety of things, such as a vacuum leak. I wouldn't worry about it unless it happens again.
I'd try a Seafoam treatment before spending $600 with the dealer. Seafoam seems to work well if the build-up hasn't gone too far. I did it at 17,000 miles and it made a difference in engine response.
Old Aug 2, 2011 | 11:09 AM
cccplus's Avatar
cccplus
dealer will clean carbon buildup under warranty. well, at least in my area. it's a common problem.
Old Aug 2, 2011 | 11:29 AM
WalthamMINI's Avatar
WalthamMINI
I just picked up a 2010 MCS, It had 13 miles on it, The next day after picking up the car did this. It started up with no problems on the third try. Then it did the same a week ago... this time it wouldnt start up unless i pressed the button and then pressed the gas pedal.. then it was fine... I brought it to the dealer and left it there for 3 days, but they were unable to duplicate it or find any codes. I then picked up the car and have been driving it since.. it has yet to return!!!!!!! ughhh..
Old Aug 2, 2011 | 01:27 PM
rick_w's Avatar
rick_w
My new 2011 MCS does the same thing once in a while when I first start it in the morning. It's fine for the rest of the day. I thought it was just "normal" behaviour. With only 500 miles on it, I doubt it's carbon buildup but I'll keep an eye on it and take it in if it gets worse.
Good luck with yours !
Old Aug 2, 2011 | 03:07 PM
6speedwtneed's Avatar
6speedwtneed
Probably HPFP
Old Aug 2, 2011 | 04:53 PM
Oakland Raiders Mini's Avatar
+1 on the High pressure fuel pump
Old Aug 2, 2011 | 08:49 PM
cub4bearindiana's Avatar
cub4bearindiana
so guys.. this first video is from tonight.. I got out of work.. car was seating in hot and humid weather for last 10 hrs..
here is another video from few days ago.. another case of car seating in nice hot weather.. not as bad as the first video though:
in this video I did add some gas later in video.. problem is showing just shortly after start button was pushed.
so do U think it is early stage of HPFP going bad?
Old Aug 3, 2011 | 07:51 AM
WalthamMINI
Originally Posted by 6speedwtneed
Probably HPFP
I wonder how I can get the dealer to replace the HPFP... He said there were no codes stored and the car was fine while sitting there! ughh
iggi
18
Feb 9, 2026 01:00 AM
Bublik
Feb 18, 2023 11:09 AM
alistaircookie
Oct 8, 2015 10:52 AM
skippermini
Aug 13, 2015 06:13 AM
oldkid6
Aug 11, 2015 08:13 PM
